Battery not Charging - High output Alternator?
(01-01-2017, 06:15 AM)curlyjoe_imp Wrote:
(12-31-2016, 09:50 AM)The ferret_imp Wrote: I think I read output is 336W somewhere.
Yes, according to the '13 service manual, the capacity of the alternator is 336 watts at 5000 rpm.
What happens to the output of the stator at say 3000 rpm? Does it decrease proportionately?
Having been playing with alternators lately, I had a look at the Honda schematic. It uses a delta wound job which produces a fair amount of current (approx 23 amps at 5000 rpm) if my math is correct. The charge curve for most 12volt motorcycle alternators are pretty much the same and they seem to reach about 90% of their output by 3000rpm and then fall off fairly linear below these revs. Considering that I have an older 4 cylinder car that only has a 40 amp alternator, 23 amps sound ok considering you have only half the number of things drawing current. If you were concerned about battery voltage and were considering connecting up any USB devices, one of these may come in handy.
http://www.ebay.com.au/itm/Double-USB-Ch...SwbYZXcjJm
28 amps isn't a heck of a lot with ~16amps of heated jackets and gloves, and 2.1amps of USB charger going. (just the headlight is 4.5amps itself). That said, I've run one heated jacket without problems.
  ABS , speedometer and battery Walter 10 837 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,859 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 739 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,242 10-28-2024, 10:58 PM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,561 10-23-2024, 02:50 PM
Last Post: rtmoto1
  CB1100 SA-E 2017 Battery Davidjill_imp 1 300 08-01-2024, 02:33 AM
  High engine revs on start up CBX1000_imp 21 2,059 06-06-2024, 02:40 AM
  wonder battery The Gecko_imp 58 5,148 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,360 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 3,089 09-14-2023, 10:08 PM
