07-14-2018, 12:58 PM
What was the cost of the battery test at the dealer?
No start - Battery replaced - No start
07-14-2018, 01:01 PM
07-14-2018, 01:02 PM
jc thanks for the end result, reading the dealer's finding is re-assuring to find a good testing regime that looks at data rather than just "see what happens" approach.
All it takes for a new battery to loose it's luster is to have it dropped just once flat on it's lower side and all plates to disconnect from their supports and all care from the factory is wasted. looks like you're in good hands here.
07-14-2018, 01:03 PM
07-14-2018, 01:30 PM
(07-14-2018, 12:58 PM)SportsterDoc_imp Wrote: What was the cost of the battery test at the dealer?$109, which is their hourly labor rate Sad litany of excuses below for not doing the job myself: [ul] [li]heat wave (can't use that one on you)[/li] [li]official paperwork for my Amazon refund (not necessarily needed)[/li] [li]need to buy a digital multimeter (still using my analog one from 1976)[/li] [li]official record with Honda in case it happens again[/li] [li]scarred by the memory of my 1981 or 1982 CB650 ownership experience--permanent electrical/charging issues [/li][/ul] But those are all just excuses. Armed with knowledge gleaned from your [url=http://cb1100forum.com/forum/showthread.php?tid=13023&pid=212135#pid212135]Post #7 - Battery Voltages and the new digital multimeter I am finally going to buy, I will easily go a level deeper next time around. P.S. If you know of a good digital multimeter in the $100 range, I will happily take a recommendation.
07-14-2018, 05:02 PM
For this purpose, your analog meter should do just fine. All you really need is a voltage reading from the battery with the bike running. If it shows normal battery voltage or less, you have a charging problem. If it's mid 13v to mid 14v, the alternator is working and the battery is likely not accepting the charge.
I know what you mean about the early 80s CB650 charging system. That thing was anemic even when the (delicate) stator was brand new.
07-14-2018, 10:27 PM
The parts man at my dealer puts a pretty expensive digital battery tester on every battery he sells whether OEM or aftermarket (they sell both). The tester runs a number of tests. He said OEM or aftermarket has failed new out of the box. And better to know at the parts counter than back in your garage or wherever.
07-15-2018, 12:43 AM
(07-14-2018, 05:02 PM)Flynrider_imp Wrote: For this purpose, your analog meter should do just fine. All you really need is a voltage reading from the battery with the bike running. If it shows normal battery voltage or less, you have a charging problem. If it's mid 13v to mid 14v, the alternator is working and the battery is likely not accepting the charge. Yes, +1, ditto. Until I inherited my dad's Fluke 77, my testing was done with a $30 Radio Shack pocket auto ranging digital meter. They have also been gifts to kids and grandkids. Don't think they are still available. https://www.radioshack.com/products/radi...multimeter An analog meter has the advantage of being able to give a basic test to capacitors. (07-14-2018, 05:02 PM)Flynrider_imp Wrote: For this purpose, your analog meter should do just fine. All you really need is a voltage reading from the battery with the bike running. If it shows normal battery voltage or less, you have a charging problem. If it's mid 13v to mid 14v, the alternator is working and the battery is likely not accepting the charge. To know if the charging system is 13.8 to 14.8, yes. However, I was looking for more: Key off is battery voltage, with 12.8 showing a full charge. It not fully charged, it will affect further testing. Key on shows extent of drop under headlight load. Instead of 12.6 (maybe 12.5), it will be less if a cell has failed. While cranking, under 10.5 will show a bad cell. This is a poor man's load test. (07-14-2018, 10:27 PM)Lord Popgun_imp Wrote: The parts man at my dealer puts a pretty expensive digital battery tester on every battery he sells whether OEM or aftermarket (they sell both). The tester runs a number of tests. He said OEM or aftermarket has failed new out of the box. And better to know at the parts counter than back in your garage or wherever. Yes, new does not always equal good. When I buy a new battery, I bring a pocket VOM with me and check the mfg date. (07-14-2018, 01:30 PM)jerrycon_imp Wrote:(07-14-2018, 12:58 PM)SportsterDoc_imp Wrote: What was the cost of the battery test at the dealer?$109, which is their hourly labor rate The dealer has to pay labor, cover costs of a building, equipment, insurance, business licenses, etc. $109 is not high and I expect it is a one hour minimum charge. However, with a VOM in hand, those tests only take a few minutes, once you access the battery posts.
07-15-2018, 07:03 AM
Yuasa is not what it used to be. After going thru 2 on my 2013, I bit the bullet and switched to a Shorai Lithium on both the CB and the B-King.
07-16-2018, 10:58 AM
The repair order invoice came in quite handy. Lake Champlain Batteries asked some fairly detailed questions. With minimum hassle, the refund is done.
-------------------------------------------------------- From: Amazon.com <payments-messages@amazon.com> Sent: Monday, July 16, 2018 4:06 PM To: email@address.com Subject: Refund on order 114-0688155-8344240 Hello, We're writing to let you know we processed your refund of $147.95 for your Order 114-0688155-8344240 from Lake Champlain Batteries. This refund is for the following item(s): Item: Yuasa YTZ14S Battery Quantity: 1 ASIN: B0024VFY86 Reason for refund: Item not satisfactory Here's the breakdown of your refund for this item: Item Refund: $147.95 Notes: Defective battery, customer already purchased a replacement from another vendor. We'll apply your refund to the following payment method(s): Credit Card: $147.95 We've processed a refund for the above order in the amount of $147.95. In most cases, once a refund has been submitted, the issuing bank will post it to your account within 3-5 business days when issued to a credit card. Refunds issued to a bank account or pin-less debit typically take 10 business days to reflect on the account balance. This time frame may vary from one financial institution to another. Have questions about our refund policy? Visit our Help section for more information: http://www.amazon.com/refunds We look forward to seeing you again soon. Sincerely, Amazon.com We're Building Earth's Most Customer-Centric Company http://www.amazon.com |
« Next Oldest | Next Newest »
| ABS , speedometer and battery | Walter | 10 | 775 |
05-02-2026, 01:29 AM Last Post: Walter |
| Yuasa Battery Life | dave | 28 | 2,478 |
04-01-2026, 04:44 AM Last Post: Tev62 |
| Rattle on right side exhaust / battery | CB1100i_imp | 4 | 657 |
04-18-2025, 02:48 AM Last Post: CB1100i_imp |
| Battery jumper | the Ferret | 14 | 1,034 |
10-28-2024, 10:58 PM Last Post: the Ferret |
| CB1100 SA-E 2017 Battery | Davidjill_imp | 1 | 272 |
08-01-2024, 02:33 AM Last Post: Gone in 60 |
| High engine revs on start up | CBX1000_imp | 21 | 1,742 |
06-06-2024, 02:40 AM Last Post: Charlie Bravo_imp |
| wonder battery | The Gecko_imp | 58 | 4,360 |
02-19-2024, 11:20 PM Last Post: mvk24_imp |
| Could old/low battery trigger misfire and engine light? | Motorsport3_imp | 13 | 1,209 |
12-17-2023, 08:41 AM Last Post: Jgarciajr40_imp |
| CEL after Jump Start | rage91_imp | 23 | 1,504 |
04-14-2023, 01:25 AM Last Post: Charlie Bravo_imp |
| Replacement Battery | dave | 54 | 3,755 |
02-04-2023, 12:41 PM Last Post: GoldOxide_imp |
