Lets talk feeler gauges
(07-18-2018, 09:43 AM)Houtman_imp Wrote: I never could own a British bike when I was young because I did not smoke.
I didn't smoke either. But when you have to overhaul a bike every 10,000 miles you learn a lot about motorcycle mechanics and the road side tricks.
I smoked, but never owned a British bike.
I admire your optimistic recollection, Nortoon. My recollection of mates who owned British bikes back in the day was that the were lucky to get them for their garage to the end of the street without having to push them home and pull them down again. On the other hand, they knew a great deal more than me about motorcycle mechanics.
Well I do not smoke either, but a Triumph, Norton, BSA was not in my budget, too hard to keep the smoke inside Lucas wiring, and leaky motors were not appealing.
I did admire the look of the 650cc Bonneville, circa mid-sixties.
One of the things I learned about BSAs is that they had a built in chain oiler. Inside the primary case is a small well that catches some of the primary chain oil. The oil passes through a tunnel to a rubber tube over the chain next to the sprocket. The result is a greasy bike. When I had mine apart I dropped some solder into the well, and removed the rubber hose. My BSAs stayed clean after that.
The chains of that era all had master links. So removing and installing a chain was easy. When I changed the motor oil, I boiled the chain in the used oil and hung it up on the clothes line with a coat hanger to allow the excess to drip off. Back then the used oil was poured down a sewer or a hole in the back yard. Wouldn't that make today's tree huggers scream.
(07-18-2018, 11:10 AM)Nortoon_imp Wrote: One of the things I learned about BSAs is that they had a built in chain oiler. Inside the primary case is a small well that catches some of the primary chain oil. The oil passes through a tunnel to a rubber tube over the chain next to the sprocket. The result is a greasy bike. When I had mine apart I dropped some solder into the well, and removed the rubber hose. My BSAs stayed clean after that.
Did mom fuss?
Do you remember when oil was sprayed on dirt roads to keep the dust down?!
Did mom fuss?
My mum didn't fuss about that. But leaving rubber tire marks on the basement stairs dragging my bikes down to the basement to work on them during the winter was not appreciated.
I remember when they use to use the oil from the transformers on hydro poles to spray on dirt roads. That did stop until the public found out it contained hazardous PCBs.
[/quote]
[/quote]
We use our old motor oil in the south to pour around the foundations of our wooden homes and keep termites out !!!!!Thumbs Up
also around fence post for the same reason plus it helps stop rot .
I mentioned before my friend in the USMC had an 850 Commando I would help him kick start .[ was a small guy ] and he loved my CB750K
Did mom fuss?
PCBs were a big deal when the 1971 Sylmar earthquake severely damaged the Sylmar Converter Station in the north part of the Los Angeles San Fernando Valley...especially since the station was right next to the Van Norman Reservoir, which lost part of the dam facing, resulting in the evacuation of ~80,000 residents.
A customer of mine "painted " his wooden veal barn with used motor oil from his tractors and this was in 1990 !
After an engine block, 750 cc & crank came back from machine shop, I put in the bathtub and give'em a good wash to remove all metal fillings +++. My mom was screaming and was very upset, so my dad intervene and said "it's better that we know what Peter is doing and where...instead of being it unknown"...
When in winter, overhauling and porting a 2-stroke, 175cc engine was completed, I let it sit on cabinet near my bed until spring..
More than certain, everyone has similar stories Thumbs Up
