Has anyone replaced their air cleaner?
(07-29-2015, 04:00 AM)The ferret_imp Wrote: In an area like Ohio .... where the ground isn't often dry and particulate content is low that filter will be good for many years and 30k miles easy.
Chip
You mean many being like 2? I'm at 15K on my 2014 Lol
(+1) North shore Lake Ontario.
After seeing what our computers suck in, in Phoenix; the desert is one dirty dang place. So I guess I better check mine. Otherwise; I don't have the mileage built up to worry about it yet.
(07-29-2015, 03:48 AM)HikerToo_imp Wrote: Thoughts on why the manual says to clean with compressed air from the outside in, why not from the inside out to dislodge the accumulated dirt?
Air flows from the inside of the filter to the outside. By blowing compressed air through the filter in the same direction, you'd basically be driving all the dirt deeper into the filter. Thus, clean from the outside in. Thumbs Up
every 50 Km
Every two years I inspect. Never been cleaned nor replaced. I think I tapped it twice against the ground to shake an insect wing out.
Of course, your mileage may vary.
if so what was the mileage when you changed it?
How dirty was the original air filter?
I was prepared to replace my air filter when I replaced the IACV, but the original one looked fine - at 17k miles. I'll check it again at about 25k.
I ended up replacing mine at 25,000 miles even thought it wasn't very dirty becuase I had the old one out and a new one on the bench.
It would have gone longer.
Factory air box design in motorcycles and cars have significantly improved in the past 20 years.
The only air filters that seem to get dirty quickly are the tiny passenger car interior filters.
  Time to check the air cleaner! The A-man 6 696 08-22-2024, 09:39 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,304 03-31-2022, 04:03 AM
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,081 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  Honda Chain Cleaner CB4ME_imp 3 351 02-09-2019, 01:48 AM
  No start - Battery replaced - No start jerrycon_imp 20 1,557 07-16-2018, 01:28 PM
Last Post: SportsterDoc
  Has anyone replaced bearings in their front wheel on a 2014 CB1100 ? Searcher_imp 0 191 05-30-2017, 07:16 PM
Last Post: Searcher_imp
  Have you replaced your battery? dave 70 4,411 02-27-2017, 09:06 AM
Last Post: olekzap_imp
  Windshield Cleaner Mtneers 17 1,203 11-27-2016, 07:44 AM
  Who has replaced their chain? sanoke_imp 17 1,268 12-26-2014, 06:06 AM
Last Post: SamEdward_imp
