Speedometer and Odometer aren't working
(04-24-2017, 05:47 AM)AzBob_imp Wrote: I bet the dash has to be matched to the ECU via some diagnostic tool since it has the ODO and ODO tampering is a no-no.
I recall seeing a post (maybe a few years back) from someone that had the gauges replaced by a dealer. The poster said that the odometer reading on the new gauges started back at 0 miles. I remember being surprised by that as I had assumed that the mileage would have been stored in the ECU. According to the poster, the dealer claimed that there was no procedure to put the proper mileage reading back.
Edit : Here's a thread about it. It seems that although it may be possible to program the new meters with the correct mileage, nobody seems to have been able to get a dealer to actually do it. http://cb1100forum.com/forum/showthread.php?tid=5547
I agree with Popgun's diagnosis - likely caused by a tweaked rear speedo sensor ring or improper air gap (.002" - .005") between sensor ring and the sensor. I've heard of speedos or ABS not working after a bike is brought in for tire change, and the tech bends the sensor ring accidentally, or puts the axle spacers on the wrong side, as on ST1300s.
On Japanese bikes, there is no correlations between the ECM and odometer mileage, not even on Gold Wings. The total mileage is burned into the speedometer's permanent memory. The trip mileage (and clock and radio presets) are recorded in the meter's temporary memory, and are erased when the battery is disconnected.
A while ago, I had to have my speedometer and entire electronic dash display changed under warranty just because the clock was slow! The dealer had to keep my car for a week because they had to be sure I wasn't putting miles on it while they had the factory (in Europe) send a meter assembly with the same mileage. Fortunately, doesn't apply to bikes.
If the sensor gap proves to be within spec; try disconnecting the ground lead from the battery for about a minute, and reconnecting.
(12-03-2016, 10:47 AM)caleb_dud_imp Wrote: Hey all,
I recently replaced my meter on my 2014 cb1100 due to a crash. It was as simple as bolting it on and plugging it in but the odometer and speedometer wont work. The tachometer is working great though. I'm wondering if I need to program it some how or if there may be a different problem. What do you all think it is? I appreciate any help I can get!
Hi comrade! I have the same problem on my 2012 cb 1100. Can you tell me how did you fix it? I was checked out speed sensor and illumination fuse, everything is ok. By the way, illumination is doesn't work too.
  ABS , speedometer and battery Walter 10 790 05-02-2026, 01:29 AM
Last Post: Walter
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,699 03-06-2026, 04:31 AM
  Basic Speedometer Troubleshooting George050994_imp 5 480 07-03-2023, 03:30 PM
Last Post: George050994_imp
  Clutch Not Working Henrik_imp 7 623 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 556 12-08-2022, 09:24 PM
Last Post: leung_imp
  New Speedometer Not Working wanobiben_imp 15 1,129 04-13-2022, 01:38 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,227 03-31-2022, 04:03 AM
  Indicators not working AlexCB_imp 8 593 02-28-2021, 03:22 AM
  One horn not working peterbaron 2 266 06-11-2020, 11:04 AM
Last Post: LakeWylieJoe_imp
  Speedometer Allen Head screw loose mhicks17_imp 1 246 09-15-2018, 02:55 PM
Last Post: max
