Rear brake rotor and new pads
Might be worth taking a few cc's of brake fluid out of the rear brake master cylinder so that there is room for expansion. Brake calipers by design of the seals should pull the piston (and pads) back a smidgeon once brake pressure is released so that they aren't pressing on the disk all the time, so if yours are theres something wrong. Given you sig says 2017 CB1100 I'm assuming that there isn't any crud corrosion build up stopping the pads/pistons from moving freely. That is the usual reason for dragging pads, I recently had to crowbar a front brake caliper off my 30+year old GSX-R750 as it was holding the disk in a vice like grip, it wasn't that badly corroded externally just crusts had formed (from being immobile for umpteen years) around the piston seals. PS I hope to pick up my new CB1100RS on saturday so will post back on how free the rear brake is when spanking new so you have a valid comparison, maybe theres a design flaw causing these to drag if mine is similar.
Thanks everyone for your help and assistance! I've got the brake working properly, it seems the caliper piston was a little sticky and needed a good cleaning. Also now that I have a few more miles on the new pads the heat build-up on the rotor is considerably less. Thanks!
Good.
(07-04-2017, 12:14 AM)Sandhog_imp Wrote: I replaced the rear brake pads on my 13' CB for the first time the other day, when I took the bike for a short test ride afterwards I noticed the rear rotor was hot, not super hot as if I had done alot of braking just hot (lets say much more than warm!). So I put the bike back on the center stand and removed/reinstalled the assembly, the caliper and pads look aligned and I had cleaned and greased the hanger pin, everything looked correct. I took the bike for another short test ride and this time without using the rear brake, again I found the rear rotor was hot.
Is it normal for the rear rotor to be on the hot side without applying the rear brake? I imagine the rotor could be getting heated to some extent given it's proximity to the exhaust but I'm concerned it's the installation of the new pads that's causing the issue. Any thoughts or suggestions on the subject would be appreciated.
Thanks.
Hi, may I know where did you get the rear brake rotor, I'm try to looking online but did not find any available right now.
  Rear brake pad replacement LongRanger_imp 39 3,637 05-03-2025, 10:45 AM
Last Post: Delphisa
  Brake Pads... Simplified Yata-Garasu_imp 20 1,873 03-02-2025, 08:28 PM
  Rear Brake Pedal Adjustment Gone in 60 12 1,135 04-04-2024, 08:18 AM
   Rear brake pedal Mixagon_imp 28 2,193 08-06-2022, 07:29 PM
Last Post: Mixagon_imp
  Rear brake pad thickness. 17-CB-002 4 454 06-18-2022, 12:42 AM
Last Post: 17-CB-002
  Any one use Ceramic Brake pads? mvk24_imp 6 679 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  rear brake question Crossfire_imp 12 891 02-18-2022, 03:02 AM
  brake pads which is best? modmaster_imp 32 2,350 08-27-2021, 10:21 AM
Last Post: jimgl3_imp
  Suggested brake pads? mvk24_imp 12 1,003 03-21-2021, 04:05 AM
  Rear brake installation? White Dog_imp 9 832 07-27-2020, 02:48 AM
