Suggested brake pads?
(03-21-2021, 03:41 AM)The ferret_imp Wrote:
(03-21-2021, 02:02 AM)mvk24_imp Wrote:
(03-20-2021, 11:53 PM)Dave_imp Wrote: My pads still have plenty of life on them but I was always told to do pads with rotors
Why would you replace perfectly good brake pads? A light sanding to clean and roughen up the surfaces should be all you need. I assume you're replacing the rotors because they're warped?
I'm pretty sure 1 of of them has been warped. I've flip flopped them and all and still get a weird pulse sometimes when braking.
I was just under the assumption the pads are worn to the rotor surface so you replace them when you get new rotors
[/quote]
I was responding to the quote above. It is not necessary to replace rotors and pads as a set. If it were, they would sell them as a set.
Obviously if there is crash damage the rotors could need replacement before 100K. The pads can be lightly sanded and reused if plenty of material left. However as long as you're in there might as well start off with all new stuff. Save your old pads for later .
[/quote]
Obviously if there is crash damage the rotors could need replacement before 100K. The pads can be lightly sanded and reused if plenty of material left. However as long as you're in there might as well start off with all new stuff. Save your old pads for later . Thats what I was thinking
What grit would you use to sand a brake pad?
You just need it rough enough to break the glaze. Back in the old days we used to use a thick piece of glass, taped the sandpaper to the glass, then rub the brake pad across it to ensure flatness, checking them every few strokes to see the color change in the pad. When the color was even across the pad it was done.
(03-21-2021, 03:59 AM)The ferret_imp Wrote: You just need it rough enough to break the glaze. Back in the old days we used to use a thick piece of glass, taped the sandpaper to the glass, then rub the brake pad across it to ensure flatness, checking them every few strokes to see the color change in the pad. When the color was even across the pad it was done.
Cool tip, thank you
  Brake Pads... Simplified Yata-Garasu_imp 20 1,728 03-02-2025, 08:28 PM
  Any one use Ceramic Brake pads? mvk24_imp 6 639 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  brake pads which is best? modmaster_imp 32 2,171 08-27-2021, 10:21 AM
Last Post: jimgl3_imp
  Rear brake rotor and new pads Sandhog_imp 13 891 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Correct part number for front brake pads Frulk_imp 7 579 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 968 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  I looked and I looked... brake pads simplest2remember_imp 3 353 07-01-2019, 08:27 AM
Last Post: itsme67_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,126 02-04-2019, 01:47 PM
  for non-ABS riders: which Brake pads are you all using? misterprofessionality 10 685 12-31-2018, 10:15 PM
Last Post: chync_imp
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,511 09-14-2018, 12:35 AM
