brake pads which is best?
Lol fact is the dealer carries a wall full of aftermarket pads hanging on little silver hooks on pegboard behind the counter and has to order in the oem pads for me because they recommend the aftermarket pads to everybody thats asks for pads.
That is funny.
What is the difference between the organic and sintered pads?
Needing to do front brakes on another bike and am totally ignorant on the subject.
(03-26-2016, 11:29 AM)4 Paws_imp Wrote: What is the difference between the organic and sintered pads?
http://powersports-blog.denniskirk.com/5...s-organic/
I bought OEM pads for my 1100A. I still have ~2.5 mm left so I haven't installed them yet.
Does anyone know why the rear pad set is so expensive ($90) for the '13 ABS vs $30 for the non ABS?
'13 RR ABS pads. $90!!! Huh
'13 RR pads. $30
[Image: a805e792a3a8febdf1834d36e7c23809.jpg]
The '13 ABS front pad sets are only $28 for RF or LF.
[Image: 124501ff061aa11ee3ef3692f32dd12d.jpg]
Thanks Kennyw.
Wow, that's a lot for a set of rear pads. The DLX rears are the same as the '13 non ABS. Does it have something to do with combined brakes. I'm still not sure what the differences are between the '13 ABS and the DLX braking system.
I want to say that having the different size islands (with the smaller one being on the leading edge) gives the ABS pads less initial bite and makes them less grabby each time you use your front brake alone.
I've never had my rears off on my '13 ABS but from what I see there, it almost looks like mine has the "regular" rear pads, as I'm pretty sure the gas slot is in the middle.
(03-27-2016, 03:04 AM)kmoney_imp Wrote: I want to say that having the different size islands (with the smaller one being on the leading edge) gives the ABS pads less initial bite and makes them less grabby each time you use your front brake alone.
I pulled my rears off on my '13 ABS to measure thickness and they are identical to the $90 replacements I had ordered (first pic above). I couldn't find aftermarket pads that look the same.
The '13 CB1100A does have the combined braking system with 3 piston calipers on the front. The center piston on the right front engages when the rear brake is applied.
Perhaps these pads are quite unique and in low demand so the manufacturer charges much more for a limited production run.
I think that's it, though I would think we share rear brakes with at least a few other C-ABS Hondas.
  Brake Pads... Simplified Yata-Garasu_imp 20 1,777 03-02-2025, 08:28 PM
  Any one use Ceramic Brake pads? mvk24_imp 6 648 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  Suggested brake pads? mvk24_imp 12 983 03-21-2021, 04:05 AM
  Rear brake rotor and new pads Sandhog_imp 13 938 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Correct part number for front brake pads Frulk_imp 7 607 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 1,005 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  I looked and I looked... brake pads simplest2remember_imp 3 383 07-01-2019, 08:27 AM
Last Post: itsme67_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,203 02-04-2019, 01:47 PM
  for non-ABS riders: which Brake pads are you all using? misterprofessionality 10 727 12-31-2018, 10:15 PM
Last Post: chync_imp
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,600 09-14-2018, 12:35 AM
