New Speedometer Not Working
Goldoxide has an incredible grip on reality, wish i could be that good....Tongue
(04-11-2022, 04:04 AM)max_imp Wrote: Goldoxide has an incredible grip on reality, wish i could be that good....Tongue
I really like [apple] pi.
(heck, I am kinda Jones'ing for it right now)
Definitely include the tire diameter in your calculations.
[/quote]
That is unfortunate. When I calculate the circumference with the tire it is about 1988mm. The default setting on the speedometer was 1900, and at that setting it felt like it was reading half the speed I was going. The unfortunate part is that the max setting is 2,999 so I am unable to double it to be more accurate. Guess I might need another speedo
[/quote]
How have you determined the actual speed you're going? Is it possible you were switch to km/h instead of mph?
[/quote]
[/quote]
I input what Goldoxide said and it still feels off. I'm going by feeling since I don't have anything else to measure speed by. I'd have to spend more time on it and have someone drive next to me to get it dialed in. I had it set for mph and it felt off. I switched it to kph and that reading feels more accurate to what I should be doing in mph.
70mph in 5th is 3600rpm on a 2014.
wanobiben - Strap on a GPS app and profile a run from zero to whatever and track the error between the GPS and the candidate instrumentation.
Also track "high speed" to zero.
  ABS , speedometer and battery Walter 10 724 05-02-2026, 01:29 AM
Last Post: Walter
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,574 03-06-2026, 04:31 AM
  Basic Speedometer Troubleshooting George050994_imp 5 464 07-03-2023, 03:30 PM
Last Post: George050994_imp
  Clutch Not Working Henrik_imp 7 606 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 521 12-08-2022, 09:24 PM
Last Post: leung_imp
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,172 03-31-2022, 04:03 AM
  Indicators not working AlexCB_imp 8 584 02-28-2021, 03:22 AM
  Speedometer and Odometer aren't working caleb_dud_imp 13 949 01-07-2021, 02:59 AM
Last Post: Gover_imp
  One horn not working peterbaron 2 249 06-11-2020, 11:04 AM
Last Post: LakeWylieJoe_imp
  Speedometer Allen Head screw loose mhicks17_imp 1 234 09-15-2018, 02:55 PM
Last Post: max
