Another Oil Thread
Thank you all for your your replies. I am almost following Mr Ferret's recommendation of not checking the oil level between oil changes (I do oil changes every 3,000 miles), but occasionally I do a quick check just to be on the safe side. I don't believe my CB1100 has ever burned a drop of oil in 30,000 miles because I have never observed a drop in the oil level, when measured through the sightglass. In 116,000+ miles I have never added a drop of oil between oil changes on my VFR800, but I have also never observed an inconsistent or low oil level when using the oil sight glass either, like on my CB1100. I'll drain out the excess oil I just put in, and keep riding. Hopefully, somebody on this forum will have a solution to why an inconsistent amount of oil drains into the crankcase when the motor is turned off; I don't believe I am the only member who has encountered this situation.
I performed a test today to try and get to the bottom of why my engine oil level changed unexplainably. I used a carpenter's level to measure exactly how level my bike sits by laying the level across the frame members located beneath the seat; this will indicate if the bike is tilted side-to-side. Much to my surprise, my driveway is not as level as I thought, and moving the bike just a couple of feet will produce a different reading in the sight glass. I discovered just how sensitive my bike is to perceived oil level when tilting it just slightly. So I take back everything I said about my bike producing inaccurate oil level measurements and place the blame totally on me. What I thought looked like an acceptable, vertical orientation of my bike when examining the oil level actually was not. I never experienced this problem on other bikes I have owned before; I assume they're just not as sensitive to slight tilting when checking the oil as the CB1100 is. From now on I think I'll use my carpenter's level to ensure my bike is properly oriented whenever I change the oil, or when I check it.
  Another tire thread: Dunlop TT900GP misterprofessionality 1 339 10-08-2025, 11:57 AM
  Another shock thread, but SHOWA JLEECB 17 1,536 02-09-2025, 11:23 PM
  another idle thread Tom_imp 11 904 11-20-2023, 01:30 PM
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 11,469 12-27-2022, 08:35 AM
   Dutch's High idle thread DutchRutter 17 1,450 09-27-2022, 01:55 AM
Last Post: DutchRutter
  new tyres' thread j3gq_imp 0 187 01-03-2022, 10:52 PM
Last Post: j3gq_imp
  another tire thread NickLHG_imp 11 850 03-05-2021, 05:50 PM
  Yet another battery thread... PowerDubs_imp 32 1,871 06-18-2020, 07:15 AM
  A Different Kind Of Oil Thread 2017EX_imp 1 224 09-13-2019, 01:20 PM
Last Post: Stichill_imp
  The Oil Thread & Filter Cross Reference mvk24_imp 13 800 05-25-2019, 09:25 PM
Last Post: jimgl3_imp
