01-23-2025, 01:41 AM
I'd say as you already have a '17 which has the dual bending valve forks...and you only weigh 150lbs- I'd probably just keep the stock rear shocks in that situation.
Another shock thread, but SHOWA
01-23-2025, 12:21 PM
(01-22-2025, 09:11 PM)Aussieflyer_imp Wrote: Hey Rdprdp01, Thank you for the benefit of your experience, insight, and dare I say wisdom. I try to subscribe to the don’t fix it if ain’t broken way of life, particularly when it comes to motorcycling. I tracked perfectly with everything you said and have opted to leave well enough alone. I think I may have been caught up in the motorcycle hype about better suspension leads to a better riding experience. My motorcycle handles very well when I am driving like the old man I am or when I feel the need to use the horse power and cornering capabilities engineered into every part of the motorcycle. I am neither tired or sore when I dismount the bikes, too. Clearly, it ain’t broke or me either. ![]() 25 years ago, I was fortunate to spend six months working in Melbourne. I love the people who adopted me like an awkward cousin who was clueless about everything. My natural drawl courtesy of the Southern United States endeared me to the locals who found it both odd and charming that I was quiet, polite, and respectful. I still remember the beauty of the Great Ocean Road and the genuine warmth and kindness of the Aussies who made sure I saw the real Australia. Cheers, mate. David (01-22-2025, 10:49 PM)m in sc_imp Wrote: i agree, race shocks aren't needed. shocks wear over time, the oil wears out, its a service item. Mos tpeople as stated, gradually get used to it and think they are just fine. The trick is to learn what a sacked out shock (or fork) feels like. Like said, mine were getting wallowy at 10k or so. when i realized it i was in the mts with my wife on the back.. and yes, riding fast. now, 99% of the time you wont feel it. However, IF you hit a bad section of road and you have a 'comfy' but worn shock, not riding fast or spiritied, its too late. It is a safety item. But it also ergonomically will help over time when the suspension does what its supposed to do. MinSC, I read all of your posts. I am particularly grateful for this one because it provides practical, pragmatic advise about what to look for and when to act. I have come to believe you have the heart of a racer even if age and maturity keeps that throttle in check. Safety is my primary concern given the health issues I have spent the last six months navigated. That said, the best medicine I have taken and the things which motivated me through the worst of rehab was the promise of the lovely exhaust note of a CB1100EX moving from the 3rd to 4th which just a little nudge. Thanks for taking the time to write the post. David(01-23-2025, 01:41 AM)PowerDubs_imp Wrote: I'd say as you already have a '17 which has the dual bending valve forks...and you only weigh 150lbs- I'd probably just keep the stock rear shocks in that situation. Copy that. I have also read many of your others posts. One that stands out is a recent post you made about the likelihood of a master link snapping on a chain. That healthy skepticism was both amusing and included a cautionary warning to not get caught up in the bulls*** that a Google search may deliver or if someone begins a statement with “I knew a guy . . .” Brilliant stuff. David
02-07-2025, 01:36 PM
I hemmed and hawed over this decision for a long time. I had changed my mind to get the ikons, but still couldn’t pull the trigger. The older resources on here with piggybacks and keeping the grab handles and luggage rack are vague. But I think from reading I can get away with piggybacks forward and a stubby spare key. Placed order for the Showas and will just learn what I need to about keeping them dialed in depending on my load. I know it’s overkill, but that’s kind of the common theme of my bike. I have magnesium rims and also ordered an active oil cooler a few months ago. Strictly unnecessary but cool.
02-08-2025, 06:21 AM
what is an active oil cooler?
02-08-2025, 11:33 AM
(02-08-2025, 06:21 AM)The ferret_imp Wrote: what is an active oil cooler? It is a brand. It also serves no purpose...and could actually be harmful. Proper engine operating temp & oil pressure, and oil flow are not something I would advise anyone to 2nd guess the engineers on.... For anyone that knows me.. I have no issues changing things I think can be improved on, so I don't often discourage things...and when I do, there is a reason.
02-08-2025, 01:20 PM
Technically it’s an earls oil cooler, active just assembles all the stuff to install for the cb1100 as a kit. I kept trying to buy one during covid but supply chain issues. They’ve only recently offered it for sale again. I have Ecu reflash so I know I don’t really need it. But if it ain’t broke, fix it anyways.
https://japan.webike.net/products/26025223.html
02-08-2025, 01:57 PM
If anyone is concerned about engine cooling- and doesn’t want to mess with the main purpose of oil- lubrication- I suggest this instead-
https://japan.webike.net/products/25952297.html Note- I do NOT think anyone needs any of that…but at the very least- why I shared is 100% safe, and much cheaper. Sent from my iPhone using Tapatalk
02-09-2025, 11:23 PM
(01-22-2025, 04:50 PM)Rdprdp01_imp Wrote: My friends, I could use some coaching. I deeply admire great engineering and hold tradesman in equally high regard. I can usually recognize fine products when I see them. This is a personal opinion and no more than that. The front forks I would leave well alone on a 2017. The dual bending valve design is there to take the harshness out of the change from low speed to high speed shocks on the bike, e.g. undulating normally (slow) and shocks from bumps, potholes etc (high). I think it does a very good job at that. Better than my all electronic Dynamic suspension up front on my 2023 BMW GS on a bad road . These forks were an upgrade to the pre 2017 bikes and they appear as expensive "suspension upgrades" on a number of Harleys. So for me I think they are very good even though they offer no damping adjustment.I think the stock rear is pretty good, nice reasonable shocks and well suited to everyday use. But definitely room for improvement if you want a specific ride, e.g. very plush/very sporty. Not really a criticism of Honda, they had to choose a ride characteristic to please the majority of riders at some sort of average weight and they went for a good all round solution at a certain price. I would invest on the rear only if you get to chose the build with a certain amount of input, such as what Wilber's and many other lower cost providers offer. They will normally deliver with the preload set (as they know the weight of the bike and you have provided your details). That just leaves you to find your favourite type of road, max out the damping, see how it goes. Then wind the damping right off and do the same run. Now you know the range you have to work with. From there on you can adjust the damping somewhere in between those limits to suit. I would have no hesitation swapping out the rear shocks if I rode this bike daily. Another manufacturer is Nitron, a UK company (available in NA) that do twin shocks for the CB1100 but the earlier models. I would be surprised if they didn't do them for the 2017MY too though. |
« Next Oldest | Next Newest »
| Another tire thread: Dunlop TT900GP | misterprofessionality | 1 | 363 |
10-08-2025, 11:57 AM Last Post: peterbaron |
| another idle thread | Tom_imp | 11 | 1,010 |
11-20-2023, 01:30 PM Last Post: the Ferret |
| The OBSERVED Valve Clearance thread | Pterodactyl_imp | 162 | 12,541 |
12-27-2022, 08:35 AM Last Post: Cormanus |
| Dutch's High idle thread | DutchRutter | 17 | 1,561 |
09-27-2022, 01:55 AM Last Post: DutchRutter |
| Another Oil Thread | dave | 11 | 965 |
09-15-2022, 09:13 AM Last Post: dave |
| new tyres' thread | j3gq_imp | 0 | 200 |
01-03-2022, 10:52 PM Last Post: j3gq_imp |
| Rear shock adjustment for pillion and bags | alexzanutto_imp | 6 | 634 |
07-20-2021, 07:49 AM Last Post: Tev62 |
| Dual bending valves on 2017 Showa Forks | jedd_imp | 6 | 611 |
06-19-2021, 02:29 AM Last Post: Houtman_imp |
| another tire thread | NickLHG_imp | 11 | 878 |
03-05-2021, 05:50 PM Last Post: Tev62 |
| Yet another battery thread... | PowerDubs_imp | 32 | 2,138 |
06-18-2020, 07:15 AM Last Post: Gone in 60 |
