Need Fatter Grips
(06-14-2014, 12:31 PM)Ole_imp Wrote:
(06-14-2014, 12:26 PM)Papabear_imp Wrote:
(06-13-2014, 11:19 PM)Tripod_imp Wrote: +1 Grip Puppies. I also tried the neoprene wraps and also didn't like the seams...
So how do you just slip them on? Heat them and stretch?
easy
cut the puppies to the correct length
place them in hot soapy water for 5 minutes
pour the hot soapy water on to your grips
slide the puppies on
easy
Yup. I liked the Grab Ons on my CB11 so much, I just installed a set on the CB750 about 1/2 hour ago. I just put some soapy water in a cup, went out to the garage and wet down the grips. Then I poured some into one end of the grip and shook it with my palms covering both ends. It took a few minutes of pulling and tugging and they slipped into place.
Now both bikes have the fat grip feel.
I use hairspray. Spray some inside the grips. Slips on easy, when dry, helps keep the grips from sliding.
I use the Grab On foam grip covers (grip condoms) on every bike, too. Can't ride without them for long.
Windex works well, too. Give 'em a good spray inside, which acts like a lube. It dries quickly, locking the grip cover in place, and with no nasty clean-ups afterward.
(I do the same thing on bicycles, which is actually where I originally got the idea. Works better than anything else I've tried.)
  Looks like I'll have to install some heated grips .... ohiorider_imp 15 1,372 10-17-2018, 04:06 AM
Last Post: ohiorider_imp
  considering the Honda heated grips for the CB1100 kvdv_imp 25 1,859 11-16-2015, 07:23 AM
Last Post: hdvalente_imp
   heated grips and pinloc systems gossman_imp 7 637 10-28-2015, 10:35 AM
Last Post: 4 Paws_imp
  Hand position on grips Offroad 9 724 07-25-2014, 12:53 AM
Last Post: The Spaceman_imp
