finally used sixht gear
(07-11-2014, 12:08 AM)Gumby 1100_imp Wrote:
(07-10-2014, 11:54 PM)shdwghst457_imp Wrote: Gumby, aren't our meters digital (but with an analog display)? I wouldn't think a true analog dial would be able to fully flex like it does when you turn on the bike.
As soon as you have a mechanical needle displaying the RPM it becomes analog. The tiny motor rotating the needle very well may be fed a digital signal, but unless the Tach has been calibrated, you have no idea how accurate the needle readout may be.
Even 'digital' LCD or LED Tachs need to be calibrated to verify accuracy. The term "digital" may imply accuracy, but it does not guaranty it Wink
That's very wrong. The DISPLAY is analog. That says nothing of the way the display gets its data. It's a digital tachometer (and speedometer) as there is no mechanical cable from the engine/wheel/driveshaft to the instruments, driving the gauge via actual revolutions. An electrical impulse is transmitted to the tach and speedo heads, that they then interpret into servo motor movements (also digital) that swing the needles above the gauge surface.
Other than the actual gauge face itself, no part of the gauge package or senders are analog.
That being said, I use 5th gear as much as possible. I usually shift into it at about 45mph. If I had a sixth, I'd probably shift into it at about 50, and I do on my other bike.
My post about weight/wind and rpm/ speed was done to see if we have some smart members on this forum.
A few people picked up on it, well done guys ! ........
I had a professor who was very fast to point out that accuracy and precision are two different things. A thermometer could read out to .0000, but if it was only accurate to +/- .1 who cares.
I don't think the spinning dial indicators is a calibration as much as it is setting the initial location. The indicators are very light to move, and can get bumped off of 0 while not running, this just gives them a known location.
  Looks like the site is finally fixed Randy B 12 1,442 08-08-2024, 02:27 PM
  Finally got one! (after 8 years) willsmith_imp 18 1,340 10-19-2021, 06:42 AM
  finally got my CB rich_imp 19 1,536 02-10-2021, 05:50 AM
Last Post: Mercurysilver_imp
  My 2017 Finally Arrived Southernoregonduck_imp 15 1,223 01-18-2021, 06:24 AM
  Finally got to actually ride it. Jambo_imp 18 1,451 09-28-2020, 08:16 PM
Last Post: Jambo_imp
  Finally happened! NickLHG_imp 23 2,012 01-11-2020, 12:15 AM
Last Post: Bheezy27403_imp
  Finally...one in the wild pdedse 22 2,086 09-24-2019, 11:36 AM
Last Post: KiowaEagle_imp
  It finally happened Randy B 20 1,418 06-19-2019, 04:37 PM
Last Post: Randy B
  The 1100 is finally out of hibernation Rocky_imp 4 438 06-09-2019, 04:11 AM
Last Post: Rocky_imp
  Finally.. dbarkdoll_imp 15 1,090 05-13-2018, 11:54 AM
