Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
I try to burn Shell or Chevron but hear Circle K is good too. In any event, you are better off getting gas from a "popular" station so that the gas is fresh.
When we first moved to Phoenix and I picked up a Suzuki Samurai, the little four cylinder was pretty sensitive to gas so every third fill up I'd used Texaco gas; otherwise I used the cheap stuff (Arco gas, rumor has it, is the worst crud to buy, you heard it here so it must be true....
). Mileage always went up with the Texaco stuff.
Got a better job and a better car so I stopped being a cheapskate and switched to Texaco or Chevron (also did a little experiment with synthetic oil and found I got about 1.5mpg better with syn than dino) and never looked back. When on vacation I shoot for tier one gas stations when I can. I tend to record my mileage and fill ups (cars only, bikes rarely get the same recordings) so I notice if mileage takes a dip; typically this means an air filter needs attention or maybe a dealer visit is in order.
I don't see a big difference between seasons and gas blends or AC use. I'm pretty much a light footed driver and will use AC almost year round.
Being a Northerner in AZ.......
Threads: 37
So everyone here runs 87? My mechanic said to always run 91 on motorcycles. Whats the difference?
Threads: 17
(10-03-2014, 01:43 AM)holy666diver_imp Wrote: So everyone here runs 87? My mechanic said to always run 91 on motorcycles. Whats the difference?
Higher octane means it contains combustion inhibitors to prevent predetonation in high compression engines. If the engine is designed for a specific octane, it generally does you no good to go higher. In fact, if you go too high you may get incomplete combustion, fouled plugs and possibly more decel popping.
The only benefit to running slightly higher octane than what the manufacturer specifies is that it often contains more detergent additives and in some cases less or no ethanol.
Likes Given: 786
87 here.
If you are in the US, that is what is specified. In tother parts of the world with a different measuring system it calls for 91 pon I believe.
So your mechanic knows more than the engineers at Honda that designed it?
Interesting
All I can say is old wives tales are difficult to purge..
Threads: 37
I guess he thought he knew more lol I'll run 87 from now on i must have missed that in the manual
(10-03-2014, 02:00 AM)The ferret_imp Wrote: (10-03-2014, 01:43 AM)holy666diver_imp Wrote: So everyone here runs 87? My mechanic said to always run 91 on motorcycles. Whats the difference?
87 here.
Interesting
87 here.
Interesting
Threads: 19
87 here.
Interesting
87 here.
Interesting
All I can say is old wives tales are difficult to purge.. Ferret is absolutely correct higher octane will also soot up your cat converter. After reading this thread. I now know why I have such a difference from station to station
I forgot about the water absorbing ethanol. I have noticed that some of these stations I visit have water sitting around after a hard rain while others don't. I'm willing to bet if I used the stations that have no sitting rain water could make a big difference. At least in my situation. Thanks everybody I have a much better understand of the problem and how to correct!
Threads: 2
Wow! I for one would love to have just a part of the money people in this country spend on premium fuel when the manufacturer of their vehicle specifies regular. When is the myth that premium means better gonna die?
One of the reasons I like my CB is because Honda tuned it to allow regular fuel. As far as the ethanol issue goes, don't get me started. Here in WA, we have it force fed to us. Basically a bad deal for m/c's, boats, and small engines, unless the whole vehicle was designed for e10.
Threads: 2
(10-03-2014, 12:48 AM)Rboe_imp Wrote: I try to burn Shell or Chevron but hear Circle K is good too. In any event, you are better off getting gas from a "popular" station so that the gas is fresh.
I used to assume ARCO was dino-swill too until I found out it's listed as a Top Tier fuel. I would stay away from independent stations like Circle K because it's not considered "top tier".
~ The Bee
Threads: 9
I pretty sure if you use the same brand of oil as you do fuel (Shell, Mobil, etc.) you'll get all around better performance.
Problem is what oil to use with the off brand fuels?
Threads: 64
Likes Given: 7
Well that was an eye opener, Circle K WAS a top tier the last time I looked - about five years ago. Now nothing may have changed, you have to participate in the Top Tier to get listed so not being listed does not necessarily mean poorer gas, but no warm fuzzy either.
So thanks for making look again Mike.
