10-03-2014, 06:21 AM
Yeap this is the thing I hate most about this bike. Poor seat release.
seat locking mechanism
10-03-2014, 08:00 AM
On the Honda, once I pull down on the release I can pull up on the back of the seat and she releases. On the Griso I find it easier to put a knee into the middle of the seat then pop the back and that will release it without a fight.
10-03-2014, 01:18 PM
(10-03-2014, 03:21 AM)ReacherCB1100_imp Wrote: I had this problem the day after I got my CB home. The mechanism releases a latch via cable at the back of the seat. Since the stock seat is somewhat flexible, I was able to bend it enough in the middle to release the front from the tank as well as the hooks around the center of the seat. I reached in and manually pulled the cable with my hand and it released the seat. It seems the cable got jammed or something, so I had to play with it a little bit until it started operating properly using the the latch on the helmet lock. No problems since. Hope this helps. thanks, you were right about the seat being so flimsy, i was able to pop it out to where i could reach the latch cable to release the seat (10-03-2014, 04:45 AM)Papa Weeley_imp Wrote: Not to play Captain Obvious here, but you are pulling down on the lever behind the keyhole, and not the helmet lock below the keyhole, right? lol nope i know what i was pulling down on (10-03-2014, 06:11 AM)Houtman_imp Wrote: I always release my Corbin seats by giving them a 'thump down" with my right hand fist on the back of the seat near the catch. wait i dont get it you push down on the seat then pull the release lever? (10-03-2014, 06:21 AM)Stealth128_imp Wrote: Yeap this is the thing I hate most about this bike. Poor seat release. definitely, i think they should have moved the helmet lock somewhere else and also made the seat more like hoods are where when you pull the latch the hood pops open
10-03-2014, 01:21 PM
So what is the diagnosis?
10-03-2014, 01:34 PM
(10-03-2014, 01:21 PM)The ferret_imp Wrote: So what is the diagnosis? well using your pic as a reference ![]() do you see where the cable feeds into the latch? there is small crevice in there that is suppose to catch onto a groove on the lever cable to hold the cable firmly in place. it seems the cable popped out of the channel and that was causing the lack of tension on the cable to release the latch. the solution: i ran the wire so there would not be that much slack for it to pop back out of its seat. but im also thinking of putting some kind of clip like those used on brake lines to be 100% sure it wont happen again.
10-04-2014, 12:17 AM
Ahhh gotcha. Weak point in the system you think? Or just a hiccup with yours?
10-04-2014, 04:50 PM
I've always had to do some jiggling to get the seat back on. Never a problem on the CB750 which has a similar design. Today was the worst. I screwed around with it for about 10 minutes and it seemed like it was in the right position, but it just wouldn't latch when I pushed the back of the seat down.
After putting on my analytical hat, I eventually figured it out. When you slide the front end of the seat in, if you push it just a bit too far, it'll seem like it's in the right position, but the back won't latch. The solution was to slide the front into position, then pull it back about 1/4" and bingo!, it latched on the first try.
10-14-2014, 08:31 AM
10-14-2014, 11:44 AM
dos yours look like this? (my 2014) If so maybe a little plug to fill the hole above the groove so it can never pop out?
[url=http://smg.photobucket.com/user/theferret111/media/2014seatlatch002_zpse11a5815.jpg.html]
10-14-2014, 09:26 PM
I have a Honda U-lock in mine and have never had any trouble. I think some of the locks on the market are bigger and that could maybe cause problems. Is yours a Honda U-lock? Just curious.
« Next Oldest | Next Newest »
| 2013 STD seat vs. 2014 DLX seat | VTR1000F_imp | 24 | 1,872 |
07-06-2016, 10:51 AM Last Post: Offroad |
| sending my seat to Baldwin Motorbike Saddles | canyonwlf7_imp | 3 | 367 |
02-23-2015, 10:10 PM Last Post: canyonwlf7_imp |
