How often should I lube the chain?
(09-12-2015, 10:32 AM)lukeduck_imp Wrote: Like they said, and don't overtighten. No scrub brushes on O-ring chains.
I had picked up a chain cleaning brush when I got the bike, hadn't owned a chain bike for years. I haven't done the chain yet but... I shouldn't use this for cleaning/maintenance on the CB1100 O-ring chain then? Huh
I also got a can of Maxima CleanUp Spray and PJ1 Blue Label Chain Lube based on their recommendation.
About every 600 mi. Have over 9k miles and chain is still spec - no adjustment needed yet. Use Honda graphite lube and clean once a year with Motorex.
Brushes can damage O-rings. Once the O-ring seal is gone the lub will leak out. Few years back I gave my now ex son-in-law my GSX750F. I had purchased it with 800 miles. One of the first maint. items was to adjust the chain, 1/2-3/4 inches of slack with rider on the bike. Then remove all grease, wax, and other stuff from chain. Apply light coating of DuPont Multi Purpose Lube (now called Chain Saver). Quick wipe down with rag and the DuPont product about every 500 miles. He called me about a year ago and reported 42,000 miles on the the chain. An over tight chain tends to not last too long. Anyway, that's the way this old fart does it, and by the way don't wash the motorcycle, you could spend that time riding or drinking Rum. Ride safe, far, and often.
I think the manual says 500 miles? I forget. I use Simple Green to clean it and Honda Chain Lube with moly to lube it.
Every 500mi. Put bike up on center stand. Take shape rag and liberally spray some WD40 on it and wipe the chain to clean grease and grime build up. Spray down with a good chain lube like Yamalube and good to go. Pretty simple.
My ATK 605 manual claimed that using kerosene or WD-40 on chains would ruin the o-rings.
My '13 CB1100 just rolled 28,600 mi. and the chain adjust indicator is just now in the green. Very little wear showing. I expect the stock chain to last at least 50,000 mi. I'll let you know.
I use 3-in-one teflon oil as a protectant when the chain is warm or after riding in rain. Since the o-rings seal in the lubricant from the factory, what we're really doing is protecting the exterior of the chain, not lubricating it, unless the o-rings have already failed in which case it may be time for new chain/sprockets.
I ride on dusty dirt/gravel roads and I agree that certain chain "lubes" will attract dirt and accelerate wear on the components.
I have roughly 2k miles on the bike and I've only had to adjust once. I use a chain wax also. Does this bike come with a superb chain or why are we so lucky with little adjustments? I had to adjust my other bikes pretty often compared to this.
Since the chain is sealed with o-rings, what we are doing is lubricating the pressure surfaces between the chain and sprockets. This will be more important to the life of the sprocket than the chain.
Obviously, over application of lubricant can cause build up of road grime so it is important to remove excess after applying lube.
(09-16-2015, 11:08 AM)dr_rock_imp Wrote: I have roughly 2k miles on the bike and I've only had to adjust once. I use a chain wax also. Does this bike come with a superb chain or why are we so lucky with little adjustments? I had to adjust my other bikes pretty often compared to this.
I think it's just the combination of the steel sprockets and factory 530 chain on a (relatively) low-powered bike. This combined with the fact that alot of people don't seem to beat and wind on our CB'S as much as other bikes.
That makes sense. It's a nice quality!
   Do I lube or not Mixagon_imp 19 2,150 10-13-2023, 09:42 PM
Last Post: Mixagon_imp
  Chain Lube LouA_imp 11 745 11-13-2017, 09:33 AM
Last Post: LongRanger_imp
