8000 miles, did your valves REALLY need adjusting?
I had my valves checked for the first time on the ST at 54,000 miles and all were in spec. I haven't done the CB yet, about to turn over 14,000 miles. Also haven't changed the brake pads, air cleaner or spark plugs.
So it sounds like 8000 miles is just precautionary. I would assume a good indicator of valves out of spec is strange noises from the top end or if the bikes power and/or mileage start to suffer? Poor idle?
Ferret, sounds good, but I will be changing my air filter well before 14K. We are dusty here in MT
DaSwami> So it sounds like 8000 miles is just precautionary.
The check of the valves is part of the (every) 8,000 miles service. Most likely there is no need for adjustment. While check is cheap, adjustment would be expensive, as the camshafts had to be dismounted.
DaSwami> I would assume a good indicator of valves out of spec is strange noises from the top end or if the bikes power and/or mileage start to suffer?
Nope. Wearung out lets the valve clearance get smaller until there is no clearance at all. This would lead to less valve noise instead of more, if becoming noticeable at all. That's why you check it.
When there is no clearance at all, the valve would not close enough and would start to burn pipes.
You can't compare the valve adjustment interval for a water-cooled engine with an air-cooled engine. I don't plan on checking my valves for the first time until 12,000 miles.
Just had my 12,000Km service completed. Clearances checked and fortunately no adjustments were required.
At 12000kms mine were adjusted by the dealer. I was charged for the labour and shims. After the service I was unhappy with another aspect of the work that was done and, being preoccupied with that, it didn't occur to me to ask for details of the valve adjustment so I can give no further detail. The cost of the service was enough to make me haul my tool box out of storage, build a work bench in my new home, and the bike hasn't been back to the dealer since. Incidentally my unhappiness with the service (I won't go into detail) was ameliorated by the dealer giving me a substantial discount on a set of winter gloves. It didn't get me back though.
No adjustments needed on mine at 8k
(07-13-2015, 05:36 PM)Pterodactyl_imp Wrote: At 12000kms mine were adjusted by the dealer. I was charged for the labour and shims. After the service I was unhappy with another aspect of the work that was done and, being preoccupied with that, it didn't occur to me to ask for details of the valve adjustment so I can give no further detail. The cost of the service was enough to make me haul my tool box out of storage, build a work bench in my new home, and the bike hasn't been back to the dealer since. Incidentally my unhappiness with the service (I won't go into detail) was ameliorated by the dealer giving me a substantial discount on a set of winter gloves. It didn't get me back though.
Sorry to hear of your experience. Yes that is the challenge isn't it? The dealer is supposed to be the "expert" and professional, so you do the right thing and take it to the dealer to get the 'best" attention. Unfortunately it can turn to custard so easily just from human error (genuine mistake) and just plain old complete lack of care and attention. Working in the automotive industry myself I see it every day. VERY frustrating! One you've lost a customer it's very hard to get them back.
Skipping the valve clearance check? Penny wise pound foolish? What if *your* bike is one of the few needing adjustment? Are you willing to risk engine damage to save a relatively small amount of money or wrench work? If I owned an 1100 (I don't, I own a 750NH) I would perform the check as per the Honda owner's manual specification. Also, if I were buying a used 1100 I would ask to see the complete maintenance records.
Checking the clearances is not beyond the skills of the average owner. At 8K I will buy the required replacement parts, pull the tank and do the check. If everything is in spec I am out only a small bit of cash and some quality time with the bike. By doing this yourself you will also know that it was done right and you can record the clearances for each valve as a reference at the next inspection. If the clearances remain stable at future inspections you will have the peace of mind to know that your Honda is in good health.
   20K miles: how this chain looks like? valkyrie_rider_imp 12 890 02-09-2024, 03:06 PM
Last Post: valkyrie_rider_imp
  Pirelli Angel GTs at 5,000 miles the Ferret 66 5,617 11-02-2021, 12:16 PM
Last Post: NovaCB1100_imp
  2.8 miles the Ferret 8 591 08-23-2021, 12:05 PM
Last Post: rboe
  Anybody looking for a 2013,230 miles? FLYTYM_imp 3 344 05-28-2021, 04:40 AM
Last Post: boynton6spd_imp
  100 miles in..1st impression Scoot_imp 20 1,627 04-08-2021, 05:19 PM
   100,000 miles on a CB? AlexCB_imp 21 1,677 03-22-2021, 04:57 AM
  How many miles.... Randy B 53 3,233 02-10-2019, 11:48 AM
  100.000 miles on a CB 1100 itsme67_imp 31 2,038 06-05-2018, 08:27 AM
  speedo miles and km for usa models...by law? pdedse 58 3,446 02-12-2018, 03:24 PM
Last Post: Ulvetanna_imp
  Eleven Whole Miles! cookiemech 33 2,303 01-31-2018, 08:29 AM
Last Post: VLJ_imp
