Likes Received: 2 in 2 posts
I put my oil filter on hand tight. They will tighten if anything. I have read about people over tightening them and ruining the gasket. At the same time, after oil changes I always take her for a good run at high engine speed and check for leaks.
Threads: 4
Final verdict was that the old gasket somehow stayed on as well so it couldn't seal well. I have no idea how that happened because I cleaned the whole area and never saw it but it will definitely never happen again.
Likes Given: 140
Well don't be too hard on yourself Josiah. You aren't the first member to report doing that. Things happen
Threads: 8
I have always changed the oil on everything I own. It happened to me about 30 years ago. Always check, have never had one stick since.
Likes Received: 605 in 271 posts
Likes Given: 784
Hey, stuff gets missed. I have done hundreds of oil changes, and have not had a double gasket issue, but just recently forgot to install the filler cap on a bike before firing it up and spraying oil everywhere lol.
No damage done, so laugh it off.
Threads: 27
yeah, I can't say a dang thing. happened to me too.
Threads: 4
(07-01-2017, 05:20 AM)The ferret_imp Wrote: Hey, stuff gets missed. I have done hundreds of oil changes, and have not had a double gasket issue, but just recently forgot to install the filler cap on a bike before firing it up and spraying oil everywhere lol.
Thanks Ferret! The only damage was the rear brake pad (probably could have been cleaned/sanded) but I replaced it. When it happened I hit the rear break and I just fishtailed and had to mainly use the engine to come to a stop. Kinda scary. Scary enough to triple check the gasket next time! Haha
(07-01-2017, 06:09 AM)jimgl3_imp Wrote: yeah, I can't say a dang thing. happened to me too.
Honestly glad to see I'm not the only one! Live and learn!
Likes Given: 140
Had to use the engine mainly to stop?? You know the bike has 2 big front disc brakes that work very well...
Threads: 125
You would be amazed how many people are afraid to use the front brakes on a motorcycle thinking they are going to dump it.
Threads: 4
(07-03-2017, 12:17 AM)Lord Popgun_imp Wrote: Had to use the engine mainly to stop?? You know the bike has 2 big front disc brakes that work very well...
At 65 in a turning lane they would work too well..... so engine first then front brakes... doesn't seem as dumb as you're making it seem.
