Wheel exchange
I'd be seriously interested in trading my '14 DLX cast wheels for your EX wire wheels, but only if it's a proven DIY swap. I'm not interested in being a guinea pig and discovering they won't work or will require motorcycle surgery or modifications.
Christian aka EarsOnWheels has a set of '14 wheels for sale and he's in the DC area.. Depending where you are in Va u are it might be worth checking em out
http://cb1100forum.com/forum/showthread.php?tid=11357
I can't remember whether it's the EX or the RS, but one's rear hub is a completely different shape to the 13 and before.
Oh, and welcome Gravity Storm.
To go from spoke to alloys is NOT a direct swap in that all the parts are not common..
The brake rotors are not interchangeable. Neither are the abs rings, nor the wheel spacers, and the rear brake caliper brackets are also different.
(09-13-2017, 11:36 AM)Jim21680_imp Wrote: Don't let this question hijack the thread...but why did Honda reduce the axle size on the 14's?
Jim, In one of the design engineer discussions that Honda posted he said it was done as it would flex more and give a better ride.
Link to article: http://world.honda.com/CB1100/engineer-talk/
And the quote: Korogi:
Take, for example, the rear axle. By reducing its diameter, the axle-shaft rigidity is reduced. The aim is to create a cushy feel, and increase the sense of security. By tapering the collar in the edge of the axle-shaft, we created a 'delay' or 'buffer' in the movement.
I think this delay, 'gentle,' or 'dull,' is what gives depth to the CB1100's character, and its an aspect we had a lot of trouble in perfecting.
My question would be, how much does an axle flex?
(09-13-2017, 09:10 PM)jedd_imp Wrote: To go from spoke to alloys is NOT a direct swap in that all the parts are not common..
If you had two bikes side by side, it is just a matter of figuring out how much to swap. The bikes have identical frames. If you swapped swing arms and everything attached it would likely be a direct swap. That would be a lot of work though.
i dont understand....you buy a new bike but not direct the RS ? or, why you dont ask the honda dealer as first befor you make the first ride ?
better now costs and troubels ?
Alp, we don't get the RS in the USA Sad
(09-13-2017, 08:28 AM)Gravity Storm_imp Wrote: New to the site, so I am not going to ask an oil question. I have just purchased a 2017 and I am not a fan of spoked wheels/tube type tires.
Does anyone know if the cast wheels of previous years can be fitted with out much trouble?
Thanks for any help.
Gravity Storm
Gravity Storm,
If you care to share...I was wondering why you would buy a 2017 and want to exchange the wires wheels when you could get a 2014 with the mags for a lower price? I know price isn't the only thing and that the 2017 is the new shiny penny but wanted to get your thoughts on how you bypassed the 2014 that has the wheels you seek. Thanks!
My reason for going to the mag wheels would be to get away from tubed tires .
  A question about wheel weights. FLYTYM_imp 24 1,924 12-01-2018, 03:55 AM
Last Post: Jim21680_imp
  Trailer wheel chock Buff7mm_imp 4 391 05-10-2018, 08:57 AM
Last Post: Buff7mm_imp
  How common are wheel & suspension upgrades? Syscrush_imp 8 669 08-09-2017, 12:22 PM
Last Post: 736cc_imp
  Front Tire Wheel Chock linuxology_imp 1 222 01-11-2015, 06:45 AM
  wheel lighting on my cb1100 jungkiwenas_imp 18 1,053 11-09-2014, 07:32 AM
Last Post: furious_blue_imp
  Wheel Care 12zsawer_imp 5 403 06-19-2014, 06:42 AM
Last Post: Huladog_imp
