Under Seat Document Bag - Is This It ??
I have a 7 megabyte CB1100A manual found on line, the month before I bought my CB...to get familiar with it beforehand.
The paper manual is at my work bench.
Also have a "cheat sheet" of basics:
Spark plug 14 mm NGK LMAR8A-9S (stock 6817)
Air filter 17210-MEJ-981 (HFA1932)
Oil filter + wrench Honda 15410-MCE-H51
Oil filter Honda 15410-MFJ-D01
Crush washer 14 mm 94109-14000
Battery YTZ14S (O'Reilly DTZ14-S $103.99)
Regulator 31600-MGZ-J01
Stator 31120-MGC-014
Pulse generator 30300-MGC-003
Diode (fuse block) 31730-MAS-601
Relays (fuse block) 38501-MEL-003
10 amp fuses stop/horn
10 amp fuses meter illumination
10 amp fuses headlight
10 amp fuses start
10 amp fuses turn/clock
The area under the seat now contains:
Compact foot pump (over battery)
Can of SealNAir (over battery)
Plug kit (over battery)
Tool pouch (rear of fuses/cross bar)
1/4 ratchet, 3" & 6" extensions
1/4" drive 3, 4, 5, 6 & 8 mm Allen bits
1/4" drive 8, 10, 12, 14 mm hex sockets
1/4" drive #2 & #3 Phillips
Open end wrenches from my last Yamaha, including 10, 12, 14 & 17.
Larger combo wrench from my last Yamaha (19 x 22mm?)
The space for the U lock has a 24" flat bungee.
Nice to have that much space!
Geezalou Doc, it's a Honda. Chances are you are never going to need any of that. You've been riding Sportsters too long ROFL
(03-14-2018, 04:43 AM)The ferret_imp Wrote: The area under the seat now contains:
Only for snugging mirrors after bumped.
Otherwise, mostly for helping others.
The 1/4 ratchet, both extensions and one of the Allen bits took care of issues on a friend's bike, last December. His breather hose was not seated, after a battery changed, just before a ride to the old Kelso Train Depot.
If I wanted to be better prepared to help H-D riders, I'd keep my Torx bits, also.
Since I ride mostly solo, in a lot of areas without cell service (even with Verizon), I try to be reasonably self-reliant.
I bought two 6 inch adjustable wrenches for the mirrors and a metric set of Allen keys for the mirror extenders on my CB500X. They are all under the seat of my CB1100 EX now.
  2013 STD seat vs. 2014 DLX seat VTR1000F_imp 24 1,967 07-06-2016, 10:51 AM
Last Post: Offroad
  "Document bag" Barkingshins_imp 9 633 04-23-2014, 04:08 PM
Last Post: flynrider
