Ear Plugs / Tinnitus
(03-10-2018, 12:58 AM)LouA_imp Wrote: I use EAR brand. They are yellow foam and work well for me. I can still hear surrounding sounds,though muted,which is just fine. A tip on putting them in- roll one between your thumb and index finger and get it as small as you can. Then (I know this sounds gross,but it works) get a bit of saliva on it and you will have an easy push into your ear canal. Works for me.
Big Grin Big Grin Big Grin that's how I do it.
(03-09-2018, 02:24 PM)jdinaz_imp Wrote: I have a serious issue with tinnitus, after every ride I suffer. The wind noise (I assume) is aggravating it. Yes, I use ear plugs, I have tried the foam ones, the ear peace ones and several others, but still hear a lot of wind. I read the posts from about a year ago, but would like an update on what others are using? I use a windshield and a full helmet to try and cut the noise, I may be making it worse with the screen, so I'll try it again naked. If I can't get a reasonable solution, I'll be forced to do the unthinkable. And I never thought I would. I love my CB.
You might also consider replacing your helmet because it might also be contributing to the problem. Some helmets are capable of significant noise reduction.
Sent from my SM-G920T using Tapatalk
Be aware also that some helmets have optional parts that help cut wind noise.
Not only does my Shoei Qwest have an optional chin skirt.. but I found out overseas Shoei sells foam pad inserts to take up the ear cup space inside that you would put speakers into.
For some reason they don't sell them in the U.S., but I found the part # and had them shipped over.
I also found overseas they sell a visor for the qwest that auto darkens in sunlight, also not available here. So I bought it. Combine that with the pinlock and things are much better than the old days. Yes- at a small reduced overall clarity.
And that Quest part number would be?
Good question. I'll have to dig up my receipts somehow.
My memory is failing me. Tongue The ear pads are available stateside. I guess it was just the auto dark lens that I ordered from overseas
Ear pads- http://www.store.shoei-helmets.com/parts...pad-b.html
Also, as I am sure you know, but in case you don't- the cheek pads are removable and have sizes up and down. That can greatly effect comfort and wind noise.
I'm a firm believer in using ear plugs but am beginning to think that what might work for one person may not work for another.
In my case, I've settled on custom-molded silicon earplugs. They fit well, last forever, are easy to clean, and seem to work better than disposable foam earplugs.
Before you resort to the unthinkable, remove your windscreen. Try riding the bike naked again. I think you'll be surprised at how much its absence will clear up most of the wind noise you suffer from. My naked CB1100 is the quietest bike in my stable -- even quieter than my R1200RT with fully adjustable windscreen.
Also, I've found that Schuberth makes a very quiet helmet. Try a C3-Pro for size and see if it doesn't help. I used to wear Arai and Shoei helmets and found them to be very noisy.
All great suggestions....of course I just bought a new Bell helmet last month. Only thing I notice is that it has less wind noise with the shield up. Windshield is coming off today.
(03-10-2018, 03:41 AM)LongRanger_imp Wrote: I'm a firm believer in using ear plugs but am beginning to think that what might work for one person may not work for another.
You can't make blanket statements like that. Any little air gap will affect noise levels greatly.
Go to http://www.LidPicker.com
You can order a kit with calipers to measure your skull. They use these measurements to give you a chart of helmets and how they all will fit you. They apply the cost towards a helmet purchase once you have the results.
Very interesting to see the results. That site is the entire reason I bought the Qwest, which I had not been looking at before.
It fits better than any helmet I have ever had otherwise so the site works well apparently. I did purchase the next thinner set of cheekpads afterward to swap in- but that is not part of the measurement process so just a little bit of a personal preference tweak to take some pressure off my gums.
Thanks to whoever first posted lidpicker on this forum when I found it. I am happy to be able to pass on the tip. Thumbs Up
Thanks Powerdubs! I’m going to order some.
Don't spend another riding day without hearing protection.
Try out some of the over the counter foam protectors, but do consider custom molded ear protection. Yes they are expensive. An Audiologist made set are the most, but I have found the ones molded at car and bike expo's are just as good and are 1/4th the price. They need to be molded so they are flat and don't extend beyond your ear. Otherwise, removing your helmet will pull them from your ears ... ouch!
After five decades of loud industrial environments, Motorcycles, light aircraft, and other loud hobbies I am left with 40% voice recognition, 80% with dual hearing aids. (These uncomfortable devices set me back 6K USD!) And I have always been careful with hearing protection!
Most of my riding is on my ST1100. In the summer months when I use a short windscreen and a full face helmet. I have used modular helmets, but they are the noisiest. especially behind a tall windscreen that creates turbulence over the helmet.
Be careful out there.
Jim
  Alpine Motosafe ear plugs franov_imp 6 569 06-08-2021, 09:36 PM
  O2 Blanking Plugs Size? will866_imp 2 294 08-14-2017, 11:53 AM
Last Post: will866_imp
  OEM Spark Plugs Back on Sale at JEGS aschem_imp 2 256 12-13-2016, 03:41 AM
Last Post: aschem_imp
  Good Deal On Spark Plugs $4.69 aschem_imp 41 2,122 11-21-2016, 07:59 AM
Last Post: BayAreaRick_imp
