You know it’s not a good day when...
This is how you change oil, http://cb1100forum.com/forum/showthread.php?tid=10993
(04-14-2018, 11:48 PM)PowerDubs_imp Wrote: When I was just a few years into driving, I changed the oil on a car but did not notice the old rubber seal from the filter stayed stuck to the block. Needless to say 2 rubber seals do NOT work better than one.
Talk about a huge mess.....
Even worse on a CB, as the filter will dump the oil right in front of the rear tire. I think I've seen a few posts over the years where someone on the forum made this mistake.
One of the things I always do after removing the old filter is to run my finger around the seating surface to make sure it's smooth and free of debris.
(04-15-2018, 06:50 AM)Cormanus_imp Wrote: This is how you change oil, http://cb1100forum.com/forum/showthread.php?tid=10993
Big Grin
It ended up being not so bad. Cleaned up the drain pan and only lost half a quart when I pulled the drain plug and put the washer back on. All is good!
