ABS , speedometer and battery
(04-22-2026, 09:50 PM)rdprdp01 Wrote: Nice work, Walter. Glad to see determination can overcome engineering when necessary!! David
Thanks David. Honda rectifiers seem to give up on about 40.000 km's or 10.000 miles in my experience. My NC 750 has the same problem. The rectifier is struggling. It seems that those connectors fit firmly, but that is the plastic part of it. You can not see if the connectors self are tight. I think they loosen up over time caused by heat. I buy a rectifier with cables coming out of it. Then I cut the connector off the bike and connect the cables directly to each other. Now there is a flexible connection further away from the rectifier. Zip ties and the rubber boot help to put it all nicely away so that water doesn't affect them. Time will tell I presume.
  Yuasa Battery Life dave 28 2,507 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 674 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,075 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 276 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,490 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,224 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Basic Speedometer Troubleshooting George050994_imp 5 476 07-03-2023, 03:30 PM
Last Post: George050994_imp
  Replacement Battery dave 54 3,933 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,148 10-18-2022, 01:55 AM
  dead battery louied_imp 62 4,221 10-16-2022, 03:48 AM
