Fender rust...how to eliminate (revisited)
peterbaron Offline
Likes Given: 996
RE: Fender rust...how to eliminate (revisited)
(06-22-2025, 11:42 PM)pdedse Wrote:
(06-22-2025, 08:05 PM)peterbaron Wrote: About 6 bolts/nuts or so.
Did twice, on my '13 and '14
Those I can see well enough, it's the disconnecting of the tail light wiring that I'm unsure of.
I removed the rear fender along with the rear light, after disconnecting the rear L and R turn signals and the rear light connectors... under the tool tray??
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
06-23-2025, 04:10 AM
pdedse Offline
Threads: 119
Likes Given: 814
Yes!  I was able to get the rear fender off.  What I was thinking was the tail light wiring...wasn't.
Some threads from the past that help:
https://m.cb1100forum.com/forum/showthre...?tid=15760
http://cb1100forum.com/forum/showthread....#pid271648
Once I realized what I needed to disconnect, then it wasn't so hard.  For the '17 models, it's only the tail light wiring, the turn signals wires stay put.
The other day I started to clean some of the rust off the underside of the rear fender; I got a good deal of it, but not fun due to the angle and hard to reach factor.  Now it should go better:
[Image: Ah26oIs.jpg]
06-23-2025, 02:50 PM
peterbaron Offline
Likes Given: 996
I have my rear turn signals mounted on the rear fender bracket due to SW MOTECH side racks
[Image: aGzUP8s.jpg]
            *Grand Chancellor*
06-23-2025, 03:27 PM
pdedse Offline
Threads: 119
Likes Given: 814
Looks like everything is going well...
30 minute soak with the rust juice, and 10 minutes with wire brush on the rear...
[Image: J0Odw4S.jpg]
Meanwhile, the front was drying and came out as hoped after removing the masking tape
[Image: nufwrEf.jpg]
[Image: mQevkGi.jpg]
Front fender is back on and the rear fender is drying.
This is what happens when your trip is cut short and now you have too much time on your hands.
I know forum member "Honda Lover" sold his bike and moved on, but a big thanks for his how-to.
06-24-2025, 01:02 PM
suhawk305 Offline
Orange County, New York
Likes Received: 168 in 72 posts
Likes Given: 368
Nice job pdedse. I used “POR15” under coatings on my fenders. After I removed the fenders from my CB, I used degreaser and steel wool to remove any bituminous material, dirt and some minor rust that accumulated under the fenders. I then washed the area with dish detergent and water. After the fenders dried, I used a foam paint brush to coat the fenders. After the fenders coating dried overnight, I spread a 2nd thin coat to assure that any missed spots are covered. https://imgur.com/gv3BU5a
In my stable:
2014 Honda CB1100 Standard
1967 Honda CB77 Superhawk
06-24-2025, 04:35 PM
pdedse Offline
Threads: 119
Likes Given: 814
(06-24-2025, 04:35 PM)suhawk305 Wrote: Nice job pdedse. I used “POR15” under coatings on my fenders. After I removed the fenders from my CB, I used degreaser and steel wool to remove any bituminous material, dirt and some minor rust that accumulated under the fenders. I then washed the area with dish detergent and water. After the fenders dried, I used a foam paint brush to coat the fenders. After the fenders coating dried overnight, I spread a 2nd thin coat to assure that any missed spots are covered. https://imgur.com/gv3BU5a
That's looks like a very thorough job, nicely done!  Who knows if it is really all that necessary, but it was a fun project and I enjoyed doing it.
06-24-2025, 07:04 PM
peterbaron Offline
Likes Given: 996
Don't forget taht Suhawk is PE, so no mickey-mouse jobs!
            *Grand Chancellor*
06-25-2025, 06:09 AM
MagnaRider Offline
Wisconsin
Threads: 14
Likes Received: 200 in 93 posts
Likes Given: 220
That POR15 is some of the best stuff I have ever used for rust. When I restored the frame on my 1977 Chevrolet pickup in highschool I used it on the entire frame and it still looks amazing 10 years later. I even used it on the leaf springs and the paint is still stuck on solid. Considering a leaf spring flexes often you would think the paint would peel off easily but it still looks amazing. Plus I use this truck to haul firewood from my woods so it gets plenty of offroad time and full of mud. Pressure wash it off and it comes back to a glorious black. 10/10 would reccomend the product. Just do NOT get it on yourself as it takes months to come off.... don't ask me how I know  Hilarious
'84 Honda Magna VF700 (Gone, but not forgotten)
'06 Yamaha VStar Classic 1100
'14 Honda CB1100 Std
06-25-2025, 06:57 AM
Whoops Offline
Utah, USA
Threads: 31
Likes Received: 117 in 50 posts
Likes Given: 64
(06-23-2025, 02:50 PM)pdedse Wrote: Some threads from the past that help:
I didn't click through on any of the links you posted, but if any of those threads you linked to ported over, I think linking to the ported threads on the new forum rather than the old forum threads might be helpful when the hosting for the old site stops and those essentially become dead links. I guess we should all probably do that if possible, sad to say.
2017 CB1100 EX | 2024 Africa Twin AS ES DCT
06-26-2025, 09:29 AM
Likes Given: 1,010
This is them:
https://cb1100forum.net/forum/showthread.php?tid=4252
https://cb1100forum.net/forum/showthread.php?tid=4774
06-26-2025, 03:00 PM
