Helmet noise
I have tinnitus too and am really sensitive to the wind noise on my helmet, reading suggestions here in a different thread, I tried the silicone plugs that mold to your ears. They work well and helped more than any of the plugs I have tried. They are great for longer rides and seat time. I also found the tighter the helmet around the cheeks the less wind noise I had, at least on my Bell helmet. For short around town rides, I like the Ear Peace plugs, they let some sound thru but do keep the wind noise down a bit at speeds less than 50MPH
When I returned to motorcycling 4 years ago, I bought a Bell MAG-9 open face helmet. It was so noisy I could not use it at highways speeds. I spent all summer trying different earplugs.
Like Suhawk 305 I finally settled on 3M E-A-R-Soft yellow neon ear plugs. Easy to install, quiet, comfortable, and stay put. After trying them I bought 200 pair for $40 on Amazon. Now I can wear my Bell helmet and ride comfortably.
I also bought a Shoei RF-1200 full face helmet that I wear when it is cold. It is quieter than the Bell, but I still wear my ear plugs for a more comfortable ride.
I've tried a ton of plugs, the best being the ones they sell shooters that is squirted into your ear then forms.
However; there are many way for sound to get into your head and the buffeting is not really attenuated by ear plugs. The skirt that tapes around the base of your helmet was the best upgrade I've done lately (switching to a car is probably the best..... Big Grin ).
May have to see if I can wrangle a new Goldwing (but dang, the $$$$Wink.
These have been the best answer for me:
https://www.amazon.com/Bose-Quietcontrol...comfort+30
You can also sync them with your phone for music or map instructions, but I usually just turn them on for the noise canceling effect. The only negatives I can find.
1. Cost....crazy high but definitely provides relief
2. You have to charge them right before riding....if you leave them laying around not on a charger they will lose their charge.
3. They have an automatic timed turn off....not sure what it is, maybe an hour? I just know when they turn off it's like rolling down a window in a car. But easy solution, just reach up and turn them back on.
4. The battery life seem 4-6 hours....good for most rides, but not for long mileage days. Although I have recharged them while eating lunch.
5. The "collar" thing seems to turn around your neck a little, not bad...you just have to make sure the leads to the ear buds stay loose without tension or it hurts your ears.
This is why you should find a solution to the earplug question: http://www.hearingtestlabs.com/motorcycle.htm (thanks Pterodactyl).
Sound is such an important source of information about the traffic (especially dense urban or suburban traffic) that I would be simply afraid to ride a motorcycle with my ears plugged.
When I was a young engineer I worked in an oil refinery and got my share of noise from turbines and all sorts of rotating equipment. Plus I also moonlighted as a professional diver, working recklessly at depths Undecided Motorbike riding with stone age helmets doesn't help either. Add some more time with power tools and you've got a mild but solid case of tinnitus Smile
As 4paws has stated tinnitus is a chronic situation, does not reverse but can get worse over time. In mu opinion here's not one single preventive measure against noise, but a combination of things, like selecting a small windshield that doesn't create turbulence around the helmet, a quiet(streamlined?) helmet, chin skirt and earplugs.
The best earplug I've come across so far is the type which you roll and squeeze between fingers and insert into the ear canal. When done properly it's dead quiet while letting important sounds pass. I have a bunch of those earplugs, because when I worked in north Africa the only transport to Saharan oilfields was twin prop airplanes of various vintages, and as you step aboard the pilots made sure that you picked up a pair, company regulations... Those earplugs work best because they are designed to deaden the noise when a 800 HP engine is two meters away and the prop is almost grazing the fuselage Big Grin
I'm guessing the frequency of the props at the cruising speed is similar to that of generated by the wind when riding... Anyway they work quite well, I keep a pair in every motorcycle jacket pocket.
I usually wear my nose canceling ear buds to movie theaters. Just went to see Avengers with my grand son and forgot them...geez why so loud? I was actually vibrated by the noise a couple of times!
I looked inside my helmet and there isn't any foam where the ear locates...I just see the other padding and a void at that spot. The hard inner shell is exposed. I realize there needs to be a space for the ear but I'm going to look into placing a bit of foam in there from one of my shop ear muffs. Hopefully my ears won't mind.
In the meantime I will look into the options listed by all ya'all
Thanks!
http://earpeace.com
  Tips to reduce noise level in helmet specialist8 42 3,439 03-12-2016, 03:44 PM
