Threads: 186
My CB seems dead on accurate at 60 when I checked. Worst bike we had was Pam's V-strom which was 5 mph optimistic at 60 mph. Because the V-strom takes it's speed pulses from the front sprocket, a change to a one tooth larger sprocket lowered the rpm's at 60 and put the speedometer dead on.
Threads: 125
(06-23-2018, 11:58 AM)dirtdreamer50_imp Wrote: I agree about Honda's accuracy. My CB500X has been spot on, at every radar speed indicator sign I have tried. So used to my other bikes being optimistic, I have to keep an eye on the speedo, when on the 500. tp dd50
FWIW, don't have any of the bikes listed below any longer, but can't remember how to change the list...tp
Wow, good to hear from you dd50!
If you care to change the information in your signature you should be able to get to that by way of the User Control Panel (User CP) associated with your account.
(For what it’s worth the speedo on my CB1100 has been spot on the few different times that I checked it in the past.)
Likes Given: 1,015
Mine has never been accurate. It's about 7 khp over—i.e. at 100 kph true, the speedo is showing 107 kph.
Threads: 28
(06-23-2018, 05:57 PM)Cormanus_imp Wrote: Mine has never been accurate. It's about 7 khp over—i.e. at 100 kph true, the speedo is showing 107 kph.
My 2103 CB500XA was about 6% optimistic and so is my 2017 CB100 EX according to those electronic speed signs. I knew something was off because I was always getting tail gated at 95 KPH on 80 KPH roads. That is the speed that you might get a warning, but not a ticket unless you were driving erratically. So that is speed most drivers have learned to use. I have to ride at 100 KPH to go with the flow. Since I have not been stopped and seldom passed over the last 4 summers, I assume I really am travelling at 95 KPH.
Threads: 39
have a couple Escort Passport 9500ix radar detectors in my cars which show GPS Speed the moment radar is detected and that will show for sure if the Speedo is off. will try to put one on my bike when i find radar on the raod and not a school zone
Threads: 9
Likes Given: 3
Tacho deviation is a must in Gernany. Cars and motorbikes must all differ from real speed and show more than you drive. Sometimes I check the shown speed of the speedometer with a value shown on a digital screen at the side off the street, which is often used here, so the rider can check his speed. All my vehicles show more. Round about 5 km/h. But the difference increases slightly with speeds faster than 50km/h. I assume the radar checked speed is also a bit out of tune. So the truth lies in between.
Wisedrum
Likes Given: 1,015
(06-24-2018, 12:44 AM)Nortoon_imp Wrote: (06-23-2018, 05:57 PM)Cormanus_imp Wrote: Mine has never been accurate. It's about 7 khp over—i.e. at 100 kph true, the speedo is showing 107 kph.
If you were caught doing 95 kph in an 80 kph zone in Queensland, it would cost you AU$250 and 3 demerit points. You’d never be allowed that sort of latitude. *sigh*
Threads: 33
Likes Given: 6
That is because you are riding a northern hemisphere bike in the southern hemisphere! Mine is the most accurate speedo I have ever experienced.
Likes Given: 1,015
Threads: 28
(06-24-2018, 07:18 AM)SportsterDoc_imp Wrote: (06-23-2018, 05:57 PM)Cormanus_imp Wrote: Mine has never been accurate. It's about 7 khp over—i.e. at 100 kph true, the speedo is showing 107 kph.
On both the CB500 and CB1100 forums I have noticed the owners with MPH speedometers find them accurate. Those of us with KPH speedometers find them optimistic.
When Canada converted to the metric system, 60 MPH roads became 80 KPH (50 MPH) roads. So that may be a reason why the speed limits on quiet highways are not strictly enforced as long as you are driving properly.
Most of my riding is done on quiet 2 lane roads an hour or more from the city. So they are not patrolled as much as the busier roads.
I am fortunate that the rush hour traffic is always headed in the opposite direction when I leave and return home.
