Motorcycle-Only Garage
(05-31-2017, 11:12 AM)Stichill_imp Wrote: Great suggestions, crew - thanks! Cormanus I was wondering if you were talking about some kind of locally-hewn timber as is done with barns? I think around here that is mostly oak sawn on site from locally felled trees.
Hardieboard, HardiePlank, etc. are great suggestions as well!
Proposals for man-cave accoutrement duly noted! Thumbs Up
I wasn't necessarily think of that unless it would be an easy and relatively inexpensive option. Any timber that will survive the weather without paint would do. I agree with Nortoon. I'd have thought oak would have been expensive. I also have no idea how weather proof it is. I fear I'm no expert.
Don’t forget to coat the ends of treated lumber when cutting to size for best results. A ceiling fan is also nice.
I dislike vinyl siding for the same reasons you stated Stichill. My house is aluminum sided, but I don't think you can even get it any longer. My house is brown, and when I extended my kitchen out the rear, brown was no longer available. We had to purchase white and have an auto body shop paint it! It was a cuss to even find the white.
What about engineered wood siding? Handles heat and cold better than wood so it won't warp, is termite and insect resistant, waterproof, and it's a green product since most of the contents are recycled.
Some suggestions.
- think about utilities (water, computer, phone, sewer)
- rough in the plumbing for a bathroom. Doesn't cost much, and you've got if you want it in the future.
- have plastic sheathing installed before they pour the floor. Keeps moisture from coming up.
- locate all the utilities in one spot. Makes for a clean installation and allows you better use of space.
- scissor trusses. Best thing I did! Opens up the space, allows more useable head room, and doesn't cost that much more to do. You can install floor trusses and have a loft for storage.
Here's a pic of the barn/shop I built in 1992. The barn measures 40' x 48' x 10'.
[url=http://s1231.photobucket.com/user/VWMX5Ray/media/DSCN6798_zps1783e3no.jpg.html][Image: e35ca2265fc3a3684fe4a4189a425898.jpg]
Great tips, guys! Guaza14: never heard of coating the ends of treated lumber...great! Ceiling fan, also great!
ClassicVW: my house is aluminum sided too! It's light yellow, done in the '70s, still looks almost new.
Razor: excellent idea on the vapor barrier under the concrete. I am going to be reworking my septic laterals this year, and the settling tank is close to the site for the new garage...plumbing in a toiler and sink drain would be feasible. I could run a water line out there at a later date if I decided to install a half bath. I will be bringing ethernet to wifi and 240V electric. Our phone is VoIP as are my cell calls when I'm on wifi.
Hadn't heard of scissor trusses...will check them out! Thanks!
  Garage Hangout Stichill 109 8,428 08-15-2019, 10:45 AM
  BMW: automatic garage door opener alprider 3 375 11-28-2018, 03:15 PM
Last Post: Inline4_imp
  Garage Fix Up redbirds_imp 25 1,788 10-04-2015, 12:43 PM
Last Post: Pterodactyl_imp
  Bike stolen from my parking garage kDiqq_imp 22 1,491 04-05-2015, 03:31 PM
Last Post: Elipten_imp
