Observation on Triangle of Light visibility
Thanks, Chuckk. Loose, exposed wiring bugs me, so I didn't want to have anything running where it didn't absolutely need to go. Hence the switch located out of the way.
To be honest, if you don't have a switch on your setup, and don't see yourself ever needing to turn them off, I wouldn't bother. I've got your lights on my Bonneville, with a switch tucked behind the headlight mounting ear out of the way. I can reach it, but since the lights are single-beam (don't have a dimming option), I've never touched the switch.
Here's the setup on the Bonnie. I guess the LEDs are a bit closer to the headlight than I originally described.
Tidy Gin60!
(11-06-2019, 05:55 AM)Gone in 60_imp Wrote: When Chuckk showed his setup, I considered moving my lights off of the fender mount to the cooler. But, I decided to leave 'em where they are. If they get noticed more, great. Plus, they are close to the bike, and where I need to park it in my tight garage, if they stuck out past the overall frame of the bike, there would be a good chance that I'd bump into them as I shinny between the bike and the back bumper of my car.
On my Bonneville, I have pretty much the same lights Chuckk has, but with clear lenses.
On the CB, I have Rigid brand Ignite single LED lights that I pulled them off of my BMW before I sold it. I'm not about to pay several hundred of dollars for something that will do the job just as well for a lot less. The Ignite setup was about $150 total. On the BMW, I adapted mounts by using shower door brackets. On the CB, I just used some simple L brackets from Home Depot. They are set off of the fender mount screw with a spacer.
The lights are connected to the empty power supply plug in the headlight bucket. The wires from each light run along the brake hoses to the area behind the headlight. I mounted a small weatherproof switch to the lower triple clamp (yellow arrow). It's discreet and out of the way, but can still be reached. I leave them on all of the time anyway, so I don't need the switch up on the handlebar. The switch toggles between high, low, and off. So, when riding at night, I can give the switch a quick tap to dim the beams.
I suspect that aux lights on the Bonnie get lost in the spread from the headlight. The presentation I went to on this topic mentioned maximizing the spacing between the points.
That's pretty much the conclusion I came to, Empty.
Thinking about moving them down on the Bonnie. There are a few good natural mounting points that would work.
here are my foggies in action.. comparing them to my buddy's new BMW 1600's lighting...
.[Image: a4e59d47e697760fc450cdc758f890e4.mp4]
Yea those are pretty visible
Bright indeed. The first bike appears to behave younger too. Smile
thanks for the kind words G.O. .. I won't tell my buddy bill, on his BMW.. I am assuming, you are talking about riders ages on your comment.. I am 76 and bill is 70.. he is a pretty good rider though..
chuckk ..
  Weird Observation About Personal Phobias Gone in 60 31 2,423 08-17-2022, 09:30 PM
