Why don't old motorcycles need a distributor?
(02-07-2020, 12:08 AM)GoldOxide_imp Wrote: Great capture m_in_sc.
Man, those were the days - maybe some folks still dwell at the point. Smile
I see what you did there GO Big Grin
lol - I am sure many here at the Forum have had some bad days trying to set the timing on their ol' cage, or even a multi-cylinder two-stroker. I personally am glad for electronics, sans an "EM pulse burst" (but that thinkin' is pretty out-dated too).
(02-06-2020, 11:53 PM)m in sc_imp Wrote: theres typically a marker on the advance unit or the points cam in the case of a 4 stroke, which spins with the points rotor.. the rotor spins with the crank. then there's a fixed mark on the cases to time against. In the case of a SOHC CB750 for example, theres an 'f' mark on the alternator rotor to set timing at idle, then there a 'll' mark that lines up at full advance for each set of points. Pints '1' set cyls 1& 4, whereas '2' sets cyls 2&3. also, theres a 't' mark for top dead center, but thats used for setting valve clearances, etc.
so, in comparison to a car, imagine the timing marks on the damper AND the distributor in the same cover on the crank basically combined.
on cam driven units, there's usually a timing mark on the alternator on the crank.
Thanks for helping me remember why, when my 76 CB750F was only a year or two old, I replaced the dual points with a Martek 440 electronic unit!
I had a *Hawk engine analyzer at the time, but it was no help.
The dwell meter made point adjustment on GM motors very simple, since GM distributor caps had a lift-up door for access with an Allen wrench to adjust with engine running.
Thanks for the trip down memory lane.
*Manufactured on Nordhoff Street, in Chatsworth, walking distance from where I grew up. They also made good quality automotive gauges.
Nah, I gave away my timing lights long before I gave away the engine analyzer/dwell meter.
Just advance until it pings, then back off a degree or two.
Doing so involves test rides/drives, which takes time, but optimizes the timing, at least for that altitude.
Cycle Tuning Unlimited was under 1,000 feet elevation, so no need to further retard for altitude...in other words, no pinging issues with altitude changes.
Even with 300 HP (1982 Chev 350 V8) in my 1973 Datsun PL620, advancing timing at altitude made a noticeable difference...so, I left the distributor clamp just snug.
(02-07-2020, 02:29 AM)m in sc_imp Wrote: try 3 sets on a triple lol. Tongue . Not hard really, at all. martek was a big rd racer, he made ignitions for quite a while especially for the cbs, kz's, and rds, was an active member of the aircooled rd club last i heard.(about 5 years ago)
It was an optical unit-very reliable. I put close to 40,000 miles on that bike from 1976-1981 with only routine maintenance.
(02-07-2020, 01:17 AM)m in sc_imp Wrote: you have no idea how many people i have had to explain to that points gap controls dwell. ...
I may only be 47 but since i was broke most of my early days of motoring, ive learned the 'old ways', including polishing point faces on a lathe. still have a dwell meter as well. I've used it on electronic setups on occasion. (helps verify that air gap is set correctly Wink )
Yep, dwell is measured in rotational degrees.
And most folks did not understand that the coil discharges through the spark plug when points open.
Or that the capacitor (condenser) is dual purpose.
When points open, it absorbs the voltage, saving point wear and when points close it discharges into the coil to facilitate quick enerization.
When the capactor was out of spec (typically 0.22 microfarad) which side had the tit and which side had the valley would indicate whether it was + or - spec.
I do not really miss points, but used them in 1982 on my V8 Datsun for reliability in remote areas.
(02-07-2020, 02:42 AM)m in sc_imp Wrote: i have to disagree, especially with 2 strokes that rev to 10k and other vehicles i have, timing is key to power and efficiency (including my 390 galaxie). But to each their own.
Disagree with optimizing timing for each individual engine, with all factors taken into consideration, such as fuel, altitude and even point gap/dwell, which affects timing? Timing is "key" and most factory settings are less than optimum. The disadvantage of running timing at optimum, is having to back off timing if running cheaper fuel.
(02-07-2020, 03:11 AM)m in sc_imp Wrote: well, I don't run cheap fuel, that's for sure. everything gets premium except the modern suv. and it definitely affects my older cars and bikes. I certainly do not run stock timing numbers, even on my stock (ish) 6-cyl 62 falcon. Thats the difference between tuned and maintained.
this is how important timing is. On a stock motored 73 kawasaki S2, i put on a dynamic timing control module, tuned in a curve and with NO PORTING put down 59 RWHP with a 45 degree power curve on the dyno graph. Chambers, timing, and jetting, thats it. the timing was the key. out of a 347 cc aircooled motor. Prior i was in the mid to high 40s at the rear wheel. I could go on and on, but i think my 'point' has been made.
No, what is your point?
I am recommending optimizing timing over stock (when feasible) and it seems that you are, also. So, what is the disagreement?
Sometimes there is not much choice.
Stovepipe Wells in Death Valley only sells 87 octane.
If timing is optimized for performance/fuel economy, it may need to be backed off, although at close to sea level, it may be OK.
My grandparents 63 Ford Falcon was an amazingly durable vehicle. It survived my teenage years. They had it for about 35 years.
170 cu in straight 6 (110 HP/), 2 speed FordoMatic. I took them in it on a 6 week 10K mile trip when I was 16. Nevada was memorable, as there were no speed limits between towns. It cruised at 85+ and got about 23 MPG.
A lot of firsts that year:
Self adjusting brakes
Transistor radio
Heater was stock, no longer an extra
No side view mirrors or seat belts
Padded dash and padded sun visors
(02-07-2020, 03:37 AM)m in sc_imp Wrote: I thought you were disagreeing with my point. I misread. we are saying the same thing.
Smile
LOL
No worries
I am sure I have done the same
Now that we are agreed that we both agree...
Advancing timing, without interfering with the piston(s) approaching TDC, maximizes burn time, which is best for not only power, but also fuel efficiency.
Advanced spark timing was explained as follows to me years ago;
If you want a woodpile to burn at twelve o'clock you don't light it at twelve, it will peak burning 10 minutes later, you light it at ten minutes to twelve, it will burn at maximum rate at twelve.
Same with a fuel mixture.
Does a modern ecu actually have a p.i.d. for the ignition timing and can you see it change in live data?
(02-07-2020, 06:33 AM)m in sc_imp Wrote: p.i.d?
if you want to get REAL weird, i'll again reference 2 (fairly modern) strokes, the timing starts low, then advances till peak torque, then retards again at higher revs because the dynamic compression goes up at higher rpms. makes for interesting tuning days.
Max, Popgun and Peter are the electronic gurus on this forum (that I know of).
Max is referencing a proportional–integral–derivative controller, which is a common PLC (programable logic controller) with algorithms.
PLCs are very common in industrial automation.
The automation company that I retired from three years ago closed three months thereafter and I think this is the only active link left on the web:
https://www.assemblymag.com/articles/918...aceability
Max, thanks for taking me down memory lane for a moment.
  Richard Hammond's motorcycles Cormanus 2 378 11-06-2025, 03:03 PM
Last Post: MagnaRider
  Race to the Clouds..motorcycles now banned the Ferret 10 892 08-15-2021, 12:20 AM
  Updated Honda motorcycles Roper_imp 30 2,561 03-07-2021, 07:51 AM
Last Post: Allen K_imp
  Italian Motorcycles on display at the Petersen Gone in 60 7 823 01-28-2020, 09:14 AM
  Kawasaki and AI for motorcycles curlyjoe 4 454 02-15-2019, 04:12 PM
  The 11 Most Important Motorcycles of All Time Rebel73_imp 9 772 02-13-2019, 06:54 AM
Last Post: Django
  If You Could Own Just Three Motorcycles.... emptysea 65 5,855 02-10-2018, 05:56 AM
Last Post: Ulvetanna_imp
  Bicycles to Motorcycles, Ships, and Planes Ulvetanna_imp 3 338 11-21-2016, 08:37 AM
  New TV show with motorcycles the Ferret 17 1,166 08-14-2016, 05:58 AM
Last Post: kmoney_imp
  Motorcycles the Ferret 25 1,929 10-30-2014, 10:34 AM
