Threads: 23
(04-20-2014, 06:42 PM)Flynrider_imp Wrote: With O-ring chains, a light lube like DuPont teflon works great. I use that and also the DuPont Silicone/Teflon lube in the orange can. Pretty much anything that doesn't have a heavy oil base will go a long way towards keeping things clean. The thick, heavy, dirt collecting lubes of the old days are for standard unsealed chains. O-rings don't need it.
Reminds me of when I used to clean the chain before lubing it on my 98 CBR600.
Used to rotate the wheel, thus slipping the chain through an old T-shirt with WD-40 on it held around the chain. One day I was in a rush to go back out, so I put the bike in first at idle and tried the same technique. What I'd created was the worlds first Honda meat grinder with a 599cc inline four!
Needless to say, the t-shirt got snagged, dragged round the sprocket and chopped the top of my thumb off! I was surprisingly calm after seeing my nice white bone poking out. I pushed the bike back down to the garage, wiped some of the blood off the tank. Then walked to hospital with my arm aloft like I was saying "please Darwin, pick me!"
Likes Given: 743
(04-20-2014, 06:56 PM)Tortuga_imp Wrote: (04-20-2014, 06:42 PM)Flynrider_imp Wrote: With O-ring chains, a light lube like DuPont teflon works great. I use that and also the DuPont Silicone/Teflon lube in the orange can. Pretty much anything that doesn't have a heavy oil base will go a long way towards keeping things clean. The thick, heavy, dirt collecting lubes of the old days are for standard unsealed chains. O-rings don't need it.
Seriously? Dayum!
Threads: 10
(04-19-2014, 07:53 PM)Aussie_imp Wrote: Uh oh! It's a chain lube thread! Popcorn time?
Tried it...don't taste to good....bit sticky....
Threads: 42
OK I will bite, this should be a long thread. When I was in biss. we kept at least 7 brands in stock all the time.
What do I use? I use Bel Ray Super Clean. It doesn't come off , the only draw back is it is white in color and makes the chain look whitish .
Threads: 17
Likes Received: 12 in 6 posts
Likes Given: 11
I used up a can of Honda lube with Graphite and bought a new one. The new one seems much thinner. I loved the old stuff. Anyone know if Honda uses a different supplier? They did that with the cleaner they used to have and now that is Original Bike Spirits cleaner. I wonder if the same thing happened with the chain lube. I'll do some research.
I am not overly anal about this stuff. It's just that the last can I had worked great on the VFR. I had difficulty getting the chain "warm" enough. It seriously lubed so well the chain didn't heat up much.
Threads: 36
I use the Pro Honda Chain Lube With White Graphite. Spray the chain every 500 miles. Clean the chain with kerosene every oil change. Buy only DID chains. I've gotten over 80,000 miles out of my chain. Got to love the current generation of o-ring chains, not like the old days when you would have to buy a new chain every time you put tires on the bike. TINK
Threads: 75
Mate, here's me thinking that was one of those urban myths. If it wasn't so serious I would cack myself laughing. Of course I believe anything you say but a picture of the thumb might keep the demons of doubt at bay  .
Back to chain cleaning. I have been very happy with MOTUL Chain Clean, followed by MOTUL (Road) Chain Lube. Minimal fling and keeps there in wet etc.
Threads: 28
Likes Received: 6 in 2 posts
(06-15-2014, 06:39 PM)Pterodactyl_imp Wrote: (04-20-2014, 06:56 PM)Tortuga_imp Wrote: (04-20-2014, 06:42 PM)Flynrider_imp Wrote: With O-ring chains, a light lube like DuPont teflon works great. I use that and also the DuPont Silicone/Teflon lube in the orange can. Pretty much anything that doesn't have a heavy oil base will go a long way towards keeping things clean. The thick, heavy, dirt collecting lubes of the old days are for standard unsealed chains. O-rings don't need it.
It's not an unusual occurrence. I was on a bike forum a few years back where someone did the same thing and ended up cutting off the tips of a few fingers. Unfortunately, he did post pics. Yechhh!
Threads: 75
Strewth, what next? Checking petrol level by the light of a match. Welding up a fume filled petrol tank. Cutting up UXBs for scrap with an oxy torch. Running your CB up to the limit while on the centre stand. Ah well I can only assume paradise is not all that bad.
Threads: 87
I agree with CA200... BelRay Super clean. He's right, the chain does turn somewhat white. But when applied to a warm chain (after a ride), and allowed to cool completely; it doesn't come off... no fuss, no muss.
