Threads: 700
Likes Given: 864
Bent shift forks, chipped gears, rounded dogs, and bikes jumping out of second gear was pretty common from guys " power shifting" into second while riding aggressively. Google " motorcycle jumping out of second gear" and you'll still find lots of threads across many forums about it, although less it seems in the last couple of years, probably due to manufacturers installing specially designed electronic quick shifters on performance models from the factory. My sons MT 10 has a factory quick shifter that works on upshifts only, but not on downshifts. Yamaha still recommends using the clutch for downshifts. Offroads BMW K1600 I think works up or down ( using a micro switch to cut power and thus load on the transmission during gear shifts)
If there is absolutely no load on the trans, it could probably be shifted without a clutch with little to no damage, but first, why bother? what is the upside? And secondly are you absolutely positively sure you are doing it right to insure there is no transmission damage?
Like I said how one treats one's own bike, is one's own business.
Threads: 18
Likes Received: 2 in 1 posts
(04-19-2022, 07:40 AM)The ferret_imp Wrote: Bent shift forks, chipped gears, rounded dogs, and bikes jumping out of second gear was pretty common from guys " power shifting" into second while riding aggressively. Google " motorcycle jumping out of second gear" and you'll still find lots of threads across many forums about it, although less it seems in the last couple of years, probably due to manufacturers installing specially designed electronic quick shifters on performance models from the factory. My sons MT 10 has a factory quick shifter that works on upshifts only, but not on downshifts. Yamaha still recommends using the clutch for downshifts. Offroads BMW K1600 I think works up or down ( using a micro switch to cut power and thus load on the transmission during gear shifts)
Like I said how one treats one's own bike, is one's own business. It sounds like you ALMOST care about the well being of the bike enough to start washing it!
Threads: 700
Likes Given: 864
Likes Received: 619 in 338 posts
Likes Given: 1,055
(04-19-2022, 08:26 AM)mvk24_imp Wrote: (04-19-2022, 07:40 AM)The ferret_imp Wrote: Bent shift forks, chipped gears, rounded dogs, and bikes jumping out of second gear was pretty common from guys " power shifting" into second while riding aggressively. Google " motorcycle jumping out of second gear" and you'll still find lots of threads across many forums about it, although less it seems in the last couple of years, probably due to manufacturers installing specially designed electronic quick shifters on performance models from the factory. My sons MT 10 has a factory quick shifter that works on upshifts only, but not on downshifts. Yamaha still recommends using the clutch for downshifts. Offroads BMW K1600 I think works up or down ( using a micro switch to cut power and thus load on the transmission during gear shifts)
2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca It sounds like you ALMOST care about the well being of the bike enough to start washing it! (04-19-2022, 08:38 AM)The ferret_imp Wrote:
Ferret, I like your answer
Threads: 700
Likes Given: 864
(04-19-2022, 09:25 AM)peterbaron_imp Wrote: (04-19-2022, 08:26 AM)mvk24_imp Wrote: (04-19-2022, 07:40 AM)The ferret_imp Wrote: Bent shift forks, chipped gears, rounded dogs, and bikes jumping out of second gear was pretty common from guys " power shifting" into second while riding aggressively. Google " motorcycle jumping out of second gear" and you'll still find lots of threads across many forums about it, although less it seems in the last couple of years, probably due to manufacturers installing specially designed electronic quick shifters on performance models from the factory. My sons MT 10 has a factory quick shifter that works on upshifts only, but not on downshifts. Yamaha still recommends using the clutch for downshifts. Offroads BMW K1600 I think works up or down ( using a micro switch to cut power and thus load on the transmission during gear shifts)
Ferret, I like your answer ![[Image: d1283710d094482d876966dc086f22fb.gif]](https://cb1100forum.net/forum/uploads/imp/202204/d1283710d094482d876966dc086f22fb.gif) It sounds like you ALMOST care about the well being of the bike enough to start washing it! (04-19-2022, 08:38 AM)The ferret_imp Wrote:
Well he has a point
Threads: 33
Likes Received: 43 in 22 posts
Likes Given: 6
(04-19-2022, 04:23 AM)The ferret_imp Wrote: worked in the industry for 17 years. Saw the results of transmission dogs and gears that weren't shifted properly WITH a clutch. If you have time to back off the throttle you have time to pull in and release the clutch IMO. Maybe if I were in a road race where every millisecond counted per lap...maybe (but I doubt if I'd do it anyway), but for a 550 pound, 85 hp street bike? What's the point? Just my opinion, your bike, do what you like with it.
I do not have as much experience as the ferret, but I did some clutch and trans repair when I operated Cycle Tuning Unlimited in 70s and 80s. One was for the owner of a local independent auto parts, where I had an account. He asked if I would check out his son's dirt bike (not a common European brand): Broken dogs, bent shift forks.
I ordered all but one part, a bent shift fork...just not available. I heated and straightened the one that could not be replaced. It should have then been heat-treated, but dad wanted to minimize cost. I think it worked fine for quite some time, but probably shifted thereafter with MUCH more care!
Threads: 129
Threads: 33
Likes Given: 6
(04-20-2022, 02:50 AM)LongRanger_imp Wrote: Doc, long time, no hear.
Yep, 5 months, but no post seemed to benefit from my 2 cents.
How is Evergreen?
Last time I was in Colorado, August 2020, I70 was closed due to fires
Time before was February-March 2019, when I70 was closed due to avalanches.
Thinking just this week about making a trip to Sun Sports Unlimited in Gunnison to purchase a 2022 Yamaha XT250, since I could register it at my daughter's address in Denver. However, local dealer is trying to order one and I want to avoid going around him.
Threads: 30
(04-18-2022, 03:35 PM)LongRanger_imp Wrote: My bikes have Shift Assist (to allow clutchless shifting) but I still disengage the clutch with every shift.
One thing for you to try: when upshifting, lightly preload the shift lever before you intend to shift, but don’t actually shift up. Just apply a little upward pressure with your toe. Then, when you want to shift, quickly disengage the clutch just a bit — just into the friction zone — and apply a bit more upward pressure to the shift lever. Your bike will upshift quickly and smoothly. After a while, this will become second nature and it won’t harm your gearbox or clutch.
BTW, the CB1100 gearbox is one of the nicest and smoothest I’ve experienced.
I've been shifting like that for years.
Threads: 78
@LongRm Let’s say there was a benefit to all this. Now ask yourself, is there a way to shift gears this way and evaluate with certainty whether it does any harm, e.g. affects the lifetime. If the answer is No, and I think it is, why take the risk.
Nevertheless, I agree what you describe works smoothly.
And one question, why is downshifting different?
