Looks like I'll have to install some heated grips ....
MTC wrote: "...I may install my replacement set on my bike, but I'm still leaning toward biting the bullet on the OEM grips."
FWIW, I had the OEM heated grips installed by the dealership when I bought the bike right out of the crate. They have worked flawlessly, and they are unobtrusive in the looks department.
-fritz
(10-16-2018, 02:12 AM)tnelson99_imp Wrote: I like Oxford heated grips for a few reasons. They'll automatically shut off after a few minutes if you forget to turn them off, the controller has 5 different settings, and they're easy to install.
I used to run the kind where you put the element under your grips but after forgetting to shut them off a couple times and killing the battery I was done with that style. I also didn't like how hot the one grip would get and the other one would hardly feel warm.
https://www.revzilla.com/motorcycle/oxfo...ated-grips
The Oxford grips look good. Where/how did you mount the switch? Does it have a bracket?
Looks like the bracket is $4.95
Mine came with a simple metal bracket that I mounted to the clutch master with some double sided sticky tape. I'll try to remember to take a picture of it tonight.
I used Oxford heated grips on my ST 1300. I thought they were great. They came with a little metal bracket that mounted under one of the switch clamp bolts.
The Oxford grips look good. Where/how did you mount the switch? Does it have a bracket? It isn't too difficult to install an inexpensive relay that only supplies power to the grip heaters when the ignition is turned on. I did this on my Guzzi 1200 Sport.
  Heated gear? ride4now_imp 10 968 12-08-2024, 09:04 PM
   Anyone planning to install Winglets along with their Rlets? bigsheep_imp 9 663 11-09-2018, 01:15 PM
  Winter Storage - thinking of a heated crate buckwheat_imp 14 1,376 06-25-2017, 10:57 AM
Last Post: stateboy_imp
  Did You Install a Honda luggage Rack on your DLX? Bighonda14_imp 3 268 08-07-2016, 08:52 AM
Last Post: Randy B
  considering the Honda heated grips for the CB1100 kvdv_imp 25 1,719 11-16-2015, 07:23 AM
Last Post: hdvalente_imp
   heated grips and pinloc systems gossman_imp 7 619 10-28-2015, 10:35 AM
Last Post: 4 Paws_imp
  Hand position on grips Offroad 9 676 07-25-2014, 12:53 AM
Last Post: The Spaceman_imp
  Need Fatter Grips B166er_imp 13 928 06-16-2014, 05:57 AM
Last Post: Papa Weeley_imp
