 Tire pressure in gravel
SS07,
Call WH, there is one guy who knows everything better than anybody else Huh
(11-16-2018, 09:30 AM)fritzwilliger_imp Wrote:
(11-15-2018, 03:16 PM)Streetshark07_imp Wrote: Sorry, but lazy American here and I have just ONE question. Which is better on a gravel hill, parked outside a hut, here at Area X.
I'm not sure if I want high (full) pressure or less or MORE!
I don't lack for miles (60k+), but knowledge!!!!BananaExcitedBeer
Thank you in advance!
-StreetShark
Generally speaking, when you are traversing over gravel, especially for long stretches, you will find that the "feel of the wheel" (handling) will be more certain with a LOWER tire pressure. The challenge, of course, would be how to reinflate to a higher tire pressure once back on hard-surfaced roads, especially if there is no air pump at a nearby gas station available.
The reason for lowering the tire pressure, by say as much as 3-5 PSI or perhaps even more, is reasonably straightforward. A higher tire pressure creates a "harder" tire tread surface so that the tire is effectively "pushing loose gravel around," thereby contributing to more uncertain handling characteristics. A lower tire pressure provides a "softer" tire tread surface so that the tire is better able to conform to the irregular gravel surfaces encountered without displacing the gravel as much, thereby leading to less slippage and uncertain "feel." BTW, this lowering of tire pressure is the same technique used by dune buggy operators (on Cape Cod, for example) when they drive over loose sand (a granular-sized version of gravel).
Hope this helps!
-fritz
Hope this helps!
-fritz Thank you! This has been the first answer in a long time that is USEFUL!!!
CHEERS!
   Urgent Tire Replacement Help CB for CST_imp 13 1,508 04-23-2024, 10:19 PM
Last Post: Ollie
  My CB hates tar snakes ...and gravel the Ferret 28 1,859 07-13-2020, 11:12 PM
  Tire pressure? memphismike_imp 16 920 06-27-2016, 11:09 AM
Last Post: Ulvetanna_imp
  Higher Tire Pressure = More Suspension Compliance? Huladog_imp 24 1,483 09-07-2015, 12:58 PM
Last Post: 4 Paws_imp
  Tire Pressure drodg33 34 2,167 06-15-2015, 03:23 AM
Last Post: drodg33
  Dirt/gravel roads LPRoad_imp 11 739 02-06-2014, 04:50 AM
Last Post: SanPete_imp
