Likes Given: 136
You can't fight in here, this is the war room!
I keep my tool kit only in there at the moment. Under the seat that is, not in the war room...
Threads: 75
(05-21-2014, 09:37 AM)Elipten_imp Wrote: Sounds like Slim Pickins emergency kit in Dr. Stangelove.
Ya got it, Tex. And, by the way, one of the all time greats.
Threads: 347
Likes Received: 845 in 465 posts
Likes Given: 977
Threads: 75
(05-21-2014, 09:40 AM)Lord Popgun_imp Wrote: You can't fight in here, this is the war room!
 The PBF, as well as the property of the Coca Cola Company, must remain intact.
Threads: 347
Likes Given: 977
(05-21-2014, 07:09 PM)Pterodactyl_imp Wrote: (05-21-2014, 09:40 AM)Lord Popgun_imp Wrote: You can't fight in here, this is the war room!
Excellent!
Threads: 6
Roadgear Programmable Tire Guage.
Bikemaster Tire and Tube Flat Repair Kit.
CruzTOOLS Speedkit JAS
CruzTOOLS combo axle wrench of requisite size for the CB1100.
Seems like a lot, but I think this mess could actually fit under the seat (they're really small and well-packaged), however, I keep the stuff in my top box. I also don't have that little plastic bin under my seat -- it no longer fit after I connected my top box's taillight harness and the rear brake light modulator, all of which are in that space.
Likes Given: 136
Sounds like a good place to mount that Bob. What kind did you get? Any pics?
Threads: 2
Well just got my tire repair kit, Cruz tools metric kit today, and one of there 27mm (as well as 22mm and 14mm) combo wrenches. I missed that they had a 32mm one as well and went with one that had a tire spoon on the other end instead from another company. The 27mm fits on top of the box just barley. The good news was that the 32mm was a bit longer and so you could actually get enough leverage to turn the axle nut, the bad news is it is a bit longer and wont easily fit in the tool box.
I may still get the 32mm combo, to put under the seat, but with what I have now I can at least tension the chain. It was actually a bit slacker then I would want from the dealer. I was able to originally move it a little over 1 1/2" now I got it down to under 1 1/4". It also lines up with the mark on the side that says where a new chain should be. I'm going to keep an eye on this, and see how often I have to adjust this, hopefully I wont very often. Everything else that I looked at seemed to be in spec. I'll check it all again at 600 miles, but keep a closer eye on the chain, probably check it each day I ride.
Threads: 1
I keep a complete tool kit under the seat;
1/4" drive sockets, wrenches, screwdriver, vise grips, hex keys, multi tool, Dynaplug tire plugger, mini-jumper cables, pressure gauge, tape, state map, Bic lighter, owners manual and a flashlight.
The only piece of road survival gear that does not fit is a Slime tire inflator. I stuff in the luggage it there is any on the bike for a particular ride. Otherwise I will have to get air after fixing a flat at a gas station.
Threads: 12
Zip ties, allen wrench, pocket knife, damp rag in a zip lock bag (to wipe the helmet shield & the front of the bike), phillips screw driver, pliers, extra ear plugs and a 10mm/8mm open wrench.
