Staintune Exhaust
Pterodactyl_imp Offline
Threads: 75
RE: Staintune Exhaust
No. Something's wrong. I think the flange is on the wrong side of the mounting point. When I get home I'll send a photo of mine. Unless I'm beaten to the draw (or post).
03-26-2016, 10:31 AM
Capo Offline
Sea Girt, New Jersey
Threads: 51
Staintune Exhaust
I'm not home to check mine out, but quite certain that you've mounted it on the wrong side of the hangar.
03-26-2016, 10:59 AM
Threads: 75
(03-26-2016, 09:36 AM)Jim21680_imp Wrote: To my fellow Staintune owners, is this spring mounting bolt in contact with the pipe on your bikes? I just noticed this today while inspecting the rear pads.
[Image: f2ac29beb085bfaec562939ac4a67b8d.jpg]
Looks like the right side of the mount. However, check mine out.
[Image: b975a2eb511141ffa99c9d6142022776.jpeg]
[Image: c7df2794d638cc9fd22fa0583410f502.jpeg]
[Image: 01d39155fdd910eaed7372bcab6d89a2.jpeg]
03-26-2016, 11:23 AM
Jim21680_imp Offline
Threads: 4
Ahh, I just realized what it is...
Look closely, you'll see my axle nut is removed, as I'm currently changing tires.
This must have allowed the swingarm to relax outward, and there you have it!
Well, that's what I'm hoping for. I'll know for sure tomorrow morning when I remount the wheel. Thanks for your help fellas!
03-26-2016, 11:28 AM
Threads: 75
That's a relief! One of the benefits of a Staintune (besides the obvious) is being able to remove or loosen and then retorque tha axle nut without removing the muffler. Same for the shocka, just need to take the muffler holding bolt out and gently push the Staintune outwards until you can get a spanner on, and then remove, the lower shocka mounting bolt. Something I really couldn't do with the OEM.
Cheers, and hope it all works out.
03-26-2016, 12:36 PM
Huladog_imp Offline
Threads: 23
Staintune Exhaust
On my current bike (the second one I've mounted a Staintune) that lower shock bolt is really close to the muffler but I was checking it at full suspension extension while mounting my Ohlins. I had about an 1/8 inch clearance. So far so good in real world riding since I doubt I'll be riding so hard to full drop the rear end, I hope.
On my first CB wasn't even close.
Aloha,
Huladog
03-26-2016, 04:19 PM
Threads: 4
Well, it turns out that my "swingarm flex" theory is not the cause of this issue, so I'm stumped.
The wheel is remounted, and the swingarm didn't close even the slightest bit (I was a bit skeptical that the rebound could be that far anyway...half an inch?)
The bike has never been dropped or bumped on that side, so I'll have to examine the mounting points for the step bracket. It could just be a manufacturing variance from Staintune.
There's got to be several other owners on here....anyone else??
03-28-2016, 08:05 AM
Threads: 75
I would doubt that it is manufacturing variance. It's difficult to tell what the problem might be purely from photographs. Are you sure you have the correct muffler? It certainly looks the right one. I'll have another look at my setup and see if I can take any measurements that might help.
03-28-2016, 08:55 AM
ChipBeck_imp Offline
Threads: 29
Jim,
I just looked at mine and the muffler is about 1/3 inch away from that bolt. Take the heat shield off of your pipe and then loosen the clamp that secures the Staintune to the header pipe. With that clamp loose grab the muffler and pull it away from that bolt. The Staintune will rotate slightly away from that bolt as you rotate it on the header pipe. If you get it straightened out that way great. If not, remove the Staintune and protect that mounting tab with cardboard while you bend it slightly with an adjustable wrench before remounting it. My first fix should work and it won't take you long. Cheers bro.
Chip
03-28-2016, 10:56 AM
Threads: 4
I spent about an hour today trying to get my Staintune to mount "correctly", but I still couldn't get the clearance others have. The bike's step bracket doesn't seem to be bent or improperly secured to the frame, so I can only imagine it's a manufacturing variance from Staintune. By loosening the mounting hardware and tugging it outward, along with reversing the washer/sleeve in the mounting point, I was able to get about a 2mm gap between the bolt & canister, which is fine with me as long as it stays that way. I'll be keeping a close eye on it in the coming weeks, but I'll save bending the mounting bracket as a last resort.
As you can see, there was definitely a bit of galvanic corrosion and abrasion going on:
[Image: 412ea88a41982aee48c7b062b1e33990.jpg]
[Image: 51edf9b283b99f5a2628c975b8038670.jpg]
And here is the washer & sleeve that I was able to reverse:
[Image: 8d23e3876556dd25f18fb979a17a3acf.jpg]
Thanks again to all that have shared some input on this; I'll keep you posted.
04-02-2016, 01:24 PM
  Staintune Banned_imp 74 5,183 04-24-2018, 04:46 AM
  Staintune 2017 physics-teacher_imp 24 2,235 02-12-2017, 02:31 PM
Last Post: Retsel_imp
  Staintune exhaust Jaychaynes_imp 3 411 06-29-2016, 09:09 AM
Last Post: Jaychaynes_imp
  staintune direct cost crutch_imp 2 347 05-08-2016, 05:17 PM
  Staintune Comparison Southpaw50_imp 38 3,327 01-20-2016, 05:41 PM
Last Post: Huladog_imp
  THE DEFINITIVE STAINTUNE vs. ARROW SLIP-ON EXHAUST THREAD!! Nemo_imp 34 3,064 01-20-2016, 05:40 PM
  Importing Staintune Slip-on to Canada Gumby 1100_imp 1 317 09-15-2015, 06:36 AM
Last Post: Papa Weeley_imp
  Will a CB1100 single exhaust fit the dual exhaust mountings Landy100_imp 1 315 05-02-2015, 09:44 AM
Last Post: Randy B
  Staintune Discoloration? HikerToo_imp 6 699 04-20-2015, 04:19 AM
  Louder Staintune?? Bbref36_imp 6 611 08-12-2014, 12:56 AM
