White House K10 - a story of regeneration
Threads: 698
Likes Given: 792
RE: White House K10 - a story of regeneration
very nice work, in the garage and in the yard
10-18-2020, 12:46 AM
Houtman_imp Offline
Threads: 115
Very nice yard and yes it is important to keep the wife happy so she lets us do our thing with our bikes.
10-18-2020, 03:34 AM
peterbaron Offline
Likes Given: 996
(10-18-2020, 03:34 AM)Houtman_imp Wrote: Very nice yard and yes it is important to keep the wife happy so she lets us do our thing with our bikes.
Absolutely, very important statement John Thumbs Up
10-18-2020, 03:54 AM
Ninemeister_imp Offline
Threads: 4
Thank you boys, glad to know we all share similar experiences.
So here we are, on the home straight so with no further ado it's full throttle to the finish line:
Side panels fitted, I did a quick check to see that both were set at the same height under the fuel tank and also both level. They were, thankfully, but to achieve symmetry the right panel had to be spring down slightly to get the screw in place, a reminder that these White House panels are very much hand made which does go some way to explain the cost.
Talking about White House, they also made the brackets at the rear of the grab handles as part of the K10 seat conversion. I played with the spacers a little to achieve a better fit to the seat, large between alloy grabs and mounts, small between bracket and frame.
OK, so now to show that not everything goes right first time. The speedo needle alignment was clearly not right as the gauge indicated 70mph whilst stationary. The answer was to strip it down (which meant removing the headlight for a 4th time!), plug in and power up from the key. In the end I discovered that you could adjust it by rotating to the mechanical stop (at ~ 6 o'clock position) and gently using the pointer to go further, then test it again. I did to a video but can't post it here, however after roughly 10 attempts the final adjustment gave me 0mph when on. Tip here is that you have to gently bend the pointer up over the dial stop to rotate clockwise and increase the static speed.
Fiddly bits over, time to fit the re-polished Wyvern 4-into-4. Lovely.
10-18-2020, 05:05 AM
Bazbro_imp Offline
Threads: 16
Mmmmm... nice. The whole job looks fantastic. Full marks, for your precision and speed of work too.
10-18-2020, 05:21 AM
Threads: 4
Side panel badging:
First job - the Honda wing badge. I went with orange to complement the gold wheels and of course match to the front & rear CB750 indicators. Can't lie - I stuck the first one on by eye. I had to trust my judgement on the position in the belief that if it looks right, it must be right.
When it came to the final decision over the 1100 Four vs 1150 Four, it came down to the quality. The 1100 version I found was a larger, chromed all metal badge, the 1150 smaller and chromed plastic (but still nice). Game over.
10-18-2020, 05:46 AM
peterbaron Offline
Likes Given: 996
The best I like are the azure paint and the Honda tank emblem. Your bike looks really good. Thumbs Up
Is this project almost complete??
Time to Biker
10-18-2020, 05:50 AM
Threads: 4
Today's jobs sorted (fixing the speedo & tracing a blown fuse on the indicators), the 1100 engine fired up first time and ran like silk. Had to go out for the afternoon, so with the chain adjustment and brake fluid change re-scheduled for one night in the week it was finally time to show the Honda some daylight.
White House K0 regeneration - done.
10-18-2020, 06:12 AM
CB1100DLX_imp Offline
Threads: 11
(10-18-2020, 06:12 AM)Ninemeister_imp Wrote: Today's jobs sorted (fixing the speedo & tracing a blown fuse on the indicators), the 1100 engine fired up first time and ran like silk. Had to go out for the afternoon, so with the chain adjustment and brake fluid change re-scheduled for one night in the week it was finally time to show the Honda some daylight.
Bravo!
10-18-2020, 06:26 AM
Bazbro_imp Offline
Threads: 16
Well done, Nine... It really is a beauty.
The colour is not that far off my friend's blue CB750 - we had one each, mine back in 1972 (mine was gold) and 1973 for his.
Whatever, it's a beautiful-looking 'bike, and you should be rightly proud of bringing it back to life.
Congratulations. Thumbs Up
10-18-2020, 06:50 AM
  14 STD W/ 17 White Tank JF Coastal_imp 63 4,735 07-23-2022, 11:50 AM
Last Post: ymtnpoah11_imp
  WHITEHOUSE:CB1100 K10 TANK:WHITE peterbaron 10 744 06-25-2018, 07:04 AM
  White House project started Ack-CB11_imp 60 4,270 10-20-2016, 03:38 AM
Last Post: use2b_imp
  Honda parts house CBpat_imp 7 689 08-20-2015, 02:55 PM
Last Post: CBpat_imp
  WHITE HOUSE AND WYVERN PICS FJR919_imp 34 2,616 05-20-2015, 11:32 AM
Last Post: FJR919_imp
  CB1100 Deluxe in White, Gray and Black CB4ME_imp 17 2,446 05-28-2014, 10:33 PM
Last Post: The Spaceman_imp
  White Gauge Faces HondaJon_imp 4 370 01-21-2014, 09:38 AM
  White House - Gold Ack-CB11_imp 12 732 09-04-2013, 04:26 AM
Last Post: Ack-CB11_imp
  "Hakofugu Cafè" #3 by White House Japan Ack-CB11_imp 21 1,462 08-22-2013, 01:00 AM
Last Post: silascopathic_imp
  Different colors ....black, silver, white OEM tanks RajunCajun_imp 1 211 06-28-2013, 06:46 AM
