Michelin Pilot Road 3s...I joined the club
Likes Received: 582 in 260 posts
Likes Given: 760
RE: Michelin Pilot Road 3s...I joined the club
Love my PR3's. If you can use more than 1/2" more I will really be impressed lol
07-17-2016, 03:07 AM
Ron in MO_imp Offline
Threads: 14
(07-17-2016, 03:07 AM)The ferret_imp Wrote: Love my PR3's. If you can use more than 1/2" more I will really be impressed lol
I don't think I have that much reckless courage at my age! Blush
07-17-2016, 04:12 AM
Likes Given: 760
Being a 160 it's got a wider profile. In order to get to the edge on that tire you have to be really cranked over. I haven't been able to do it. I think Pterodactyl has though.
07-17-2016, 04:23 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
Got to test ride the RP3's this morning - oh man on corners they gave me a scare. They kinda drop in and unlike the stock tires it takes a wee bit of effort to get back up again. Weird. Will take a bit to get used to them. Not as flickable as the stock units because of the added input to get right again; but initial turn in effort is much smaller than the stock tires.
I found my self dropping into a much sharper turn than expected or wanted and a few times I just held on and let her track through otherwise I was trying to dial her back which was too much and had to drop her back in again - oiy! Have not had a tire do this before. Gonna be a learning curve with these.
07-22-2016, 04:06 AM
dsan1964_imp Offline
Threads: 18
I ordered mine..
08-14-2016, 12:14 PM
RidingMidMo_imp Offline
Threads: 0
I put 1000 miles on my new ones earlier this month. I love them! What a difference from the stock tires.
08-14-2016, 11:26 PM
CBryder_imp Offline
Threads: 2
I replaced my worn out stock Dunlops with PR3s this Satuday. The 2 things that I have noticed the most so far are; stable lines in the corners, and the little shimmy the Dunlops gave me every time I got on a snake is now almost nonexistent.
Sent from my SM-G920T using Tapatalk
08-15-2016, 01:39 AM
mininsx_imp Offline
Threads: 11
(07-22-2016, 04:06 AM)Rboe_imp Wrote: Got to test ride the RP3's this morning - oh man on corners they gave me a scare. They kinda drop in and unlike the stock tires it takes a wee bit of effort to get back up again. Weird. Will take a bit to get used to them. Not as flickable as the stock units because of the added input to get right again; but initial turn in effort is much smaller than the stock tires.
And that's why I stuck with the stock sizes. I had a '99 Nighthawk 750 years ago and I put a 150 on the rear instead of a stock size 140 and experienced the same thing. The taller rear tire made it "drop into" turns with very little input on the handlebars. I can't imagine what a 160 would do. To each his own...
08-16-2016, 12:10 AM
Likes Given: 760
That's interesting because none of the rest of us, and there are quite a few of us that have made the transition to the Michelins, have had this experience. I ride just about nothing but curves on my local roads and for me they are very natural going into turns, and in transitions from right to left and back to right again, never a scary moment.
08-16-2016, 12:24 AM
Ulvetanna_imp Offline
Threads: 78
The rear ride height is taller because of the rim being too narrow to really quite accommodate the 160. You could try to drop the suspension to the next softer setting but the stock shocks are pretty flaccid, I don't know what that would be like for your setup as far as stability.
You could also increase the preload on the front end and leave the shocks alone; this bike is really responsive to that, but then the overall ride height would be taller.
That's the issue with one tire being a width mismatch; it puts the contact patch farther off center when you lean the bike. Modern bikes are designed to accommodate this with the very wide tires used but still feel very different than the narrower tires on the CB1100 and take a different kind of technique and feel.
I just do not like mismatched sizes, and am glad that now after three years I can get the right sizes in a good tire.
As far as getting to the edge of any given tire, the only tire that can be "edged" is a stock 140/70, as the bike starts to scrape pegs well before a 150 or 160 can ever be touched near the edge. There really should be no concerns about that for the vast majority of riders.
08-16-2016, 12:32 AM
  Michelin PR3's: where are you buying them? misterprofessionality 7 621 05-03-2018, 04:36 PM
  Michelin Road Pilot 3 Tires SOURCE! 736cc_imp 2 395 08-18-2017, 01:06 AM
Last Post: jedd_imp
  59 Club decal applied... Rebel73_imp 10 919 04-17-2015, 01:30 AM
Last Post: Rebel73_imp
  Review Michelin Road 3's CIP57_imp 59 3,848 07-05-2014, 06:33 PM
Last Post: Pterodactyl_imp
  Our own Ton club Ack-CB11_imp 25 1,630 01-17-2014, 02:41 PM
Last Post: Buffalorider_imp
