How To do your own 600 mile service
loool aight than Wink
Hey Riko,
There are three things at issue in the oil change cycle: the plastic oil filler cap, the metal oil drain plug under the engine and the crush washer that goes on that drain plug. You do not need either a new filler cap or drain plug, but Honda recommends using a new crush washer each time the oil is changed.
Does that make sense?
jep got tgat already, the words in the first post caused confusion, thats all
While checking torque settings is asking a bit much it well worth checking that nothing is coming loose. My first service found my top left hand rear shocker nut attempting to escape.
This, friends, is why you don't torque the oil filter to factory specs. This is after an end oil wrench, strap wrench, pipe wrench, and finally a pair of channel locks. The filter collapsed and started leaking oil all over before I was finally able to break it loose, and I'm darn lucky that it did finally come loose. Hand-tighten plus about 1/8 turn with the wrench for me, please...
Yikes! That was really on there. Is it safe to assume (given the thread title) that this is how it came from the factory? I recall on many of the '13 models that the factory filter was on unusually tight (including mine) and the oil drain plug was unusually loose.
Wow...yeah I always go hand tight,Then a bit more by hand...
I hope this isn't the factory oil filter, the bike had 2500 miles on it when I bought it.
(07-11-2016, 11:38 AM)Flynrider_imp Wrote: Yikes! That was really on there. Is it safe to assume (given the thread title) that this is how it came from the factory? I recall on many of the '13 models that the factory filter was on unusually tight (including mine) and the oil drain plug was unusually loose.
(07-11-2016, 12:32 PM)Shinchan_imp Wrote: I hope this isn't the factory oil filter, the bike had 2500 miles on it when I bought it.
My factory one was a bugger to get off...
When I did the first oil change on my CB500XA, I was going to use Penny's plastic kitchen boa (used for removing jar tops) to remove the oil filter. At the dealers service desk Olivia suggested I buy the Honda oil filter wrench for $5. It is a light metal cap that fits over the top of the filter. It has a sturdy nut welded to the top so the filter can be removed with a wrench. Good thing I did because the filter was very tight and would have broken the plastic boa. Happy wife, happy life!
  Service manual Billie_imp 32 2,993 11-27-2025, 06:35 AM
Last Post: TheLegend
  2018 CB1100EX just collected from service Motorsport3_imp 5 560 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,257 04-23-2023, 01:35 AM
  Service and Repair Manual alexzanutto_imp 5 652 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Factory Service Manual Download ??? markT_imp 24 1,893 10-14-2021, 09:30 AM
Last Post: furious_blue_imp
  Service indicator - unleashed j3gq_imp 6 632 07-27-2021, 03:12 AM
  Free Honda SERVICE Manuals dan88_imp 9 912 03-30-2021, 08:18 PM
Last Post: Enzofour_imp
  DLX is back from service LongRanger_imp 18 1,279 01-14-2021, 08:00 AM
  First Service larryblag_imp 46 3,049 09-18-2020, 09:11 PM
Last Post: spechg
  Honda Common Service Manual pekingduck 35 2,623 04-26-2020, 03:12 AM
