Whitehouse K17 mods...
Bazbro_imp Offline
Threads: 16
RE: Whitehouse K17 mods...
And they look even better with the four-into-four Wyvern silences!
[Image: f5b01c19d6bdbaf213cd1251da46aee0.jpg]
09-27-2020, 05:18 PM
Cormanus Online
Threads: 349
Likes Given: 1,030
Agreed.
09-27-2020, 06:26 PM
Ninemeister_imp Offline
Threads: 4
(09-27-2020, 05:18 PM)Bazbro_imp Wrote: And they look even better with the four-into-four Wyvern silences!
Beer
Cool
09-27-2020, 11:50 PM
Bazbro_imp Offline
Threads: 16
A question, guys..
Can a CB1100 engine be run with fuel supplied only by gravity, or MUST the fuel pump be connected?
The reason I ask is that I have identified a source of CB1100-fit fuel tanks that are look-alike CB750, with gravity fuel taps. The kicker is that they are £75 (unpainted) compared to Samurider's Whitehouse ones, at £1,600 (unpainted)!!
I'll check the Workshop Manual tomorrow to see if I can elucidate any info there, but I thought I'd ask you more knowledgeable guys first.
So if the CB1100 engine will happy run WITHOUT the fuel pump, I could be onto something... Celebrate
09-28-2020, 06:24 AM
Threads: 4
(09-28-2020, 06:24 AM)Bazbro_imp Wrote: A question, guys..
Sorry Barry, the answer is no.
The CB1100 is a fuel injected engine which requires a constant fuel pressure of around 50psi at idle (under vacuum), rising to ~57psi at full throttle.
That said, the engine does not need to use the original in-tank fuel pump, you could use an external pump as long as it delivered the same pressure.
I should have also mentioned that the in-tank fuel pump incorporates a fuel pressure regulator, hence the external pump would have to be internally regulated or use an in-line regulator on the supply line.
09-28-2020, 06:32 AM
Bazbro_imp Offline
Threads: 16
Very many thanks, Nine. An added complication but not insurmountable - just more cost and difficulty!
I'll have a look at the Workshop Manual when I get up and see what can be done.
Thanks again. Thumbs Up
09-28-2020, 03:47 PM
Bazbro_imp Offline
Threads: 16
Darn it! On closely checking the dimensions of this remarkably cheap tank, whilst it has the LOOK of a CB750 tank, it's small - much smaller, just 9 litres! So back to the drawing board.
I've contacted an Indian company, who make excellent reproduction tanks, to ask them about this very question, namely, a 1972 CB750-looking tank that will fit a 2011-2020 CB1100. But don't hold yer breath...
I'll keep everyone posted if I hear anything. Meanwhile, I await Ninemeister's write-up on his K10/17. Happy days!
09-28-2020, 07:10 PM
Threads: 4
(09-28-2020, 07:10 PM)Bazbro_imp Wrote: Darn it! On closely checking the dimensions of this remarkably cheap tank, whilst it has the LOOK of a CB750 tank, it's small - much smaller, just 9 litres! So back to the drawing board.
Funny you mention Indian tanks. I'm going to buy an aluminium tank for my BMW Cafe project and have talked to a couple of companies out there who can make me a tank for around £400-£500.
I'm sure if you sent a stock CB11 tank the same guys could either re-fashion it into a very passable (but larger) CB750 unit or make you a new one in alloy?
09-28-2020, 11:50 PM
Bazbro_imp Offline
Threads: 16
That's the EXACT conversations that I've had with my Indian contact ('Bikenation'), funnily enough. He suggested that I send him a tank for him to fashion into what I suggest, but I've pointed out to him that, as far as I can tell, they would need TWO tanks - a CB750K2 to form the outer, visible shell, and a CB1100EX/RS bottom part to weld underneath. And as I'm not made of money (otherwise I'd buy the Whitehouse one I've been telling him about!!) I just cannot buy TWO tanks, plus their postage to India! I'll see if he comes back to me with anything.
An alloy replica CB750 tank has ENORMOUS appeal...!! Clap
09-29-2020, 12:08 AM
Houtman_imp Offline
Threads: 115
There is a company in your neighborhood making beautiful alu tanks for bikes , they make them for Gold Stars etc.
09-29-2020, 12:48 AM
  Gauge Mods Seancampbell777_imp 11 1,203 10-16-2024, 04:14 AM
  Short mods list and experience with each for those considering. Motomike7_imp 6 637 04-07-2023, 11:34 PM
Last Post: 1973cb750
  2 small mods until the weather changes inditx_imp 10 1,066 01-02-2023, 10:31 AM
Last Post: inditx_imp
  Mods to OEM seats? 2014ltdltz 7 823 07-05-2022, 05:56 AM
  Best suspension mods? gretle_2.0 6 620 05-10-2022, 06:25 AM
  Winter Mods finished, time to ride! Phadreus_imp 3 546 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Mods Mods Mods Latinrudeboi13_imp 12 1,057 08-23-2021, 01:11 PM
Last Post: Rox_imp
  Mr.P's CB mods, mark II misterprofessionality 18 1,534 05-21-2020, 06:45 PM
  New Mods 89gaz89_imp 1 334 05-15-2020, 08:08 AM
  Newly Purchased 2013 With some Mods HigginsNYC_imp 26 2,124 03-14-2020, 12:02 AM
Last Post: Cobalt23_imp
