HARLEY DAVIDSON V-Rod
#91
(02-07-2019, 09:58 AM)LongRanger_imp Wrote: I'm not knocking Moto Guzzi -- I owned two V7's and thought they were endearing bikes, but they looked better than they were built. If it wasn't for the dismal dealership situation in the U.S., I'd probably still own one of them and not my DLX.
Endearing is a good word choice!
I was in love when I first got it, then the cold nature of warm starts wore on me and the Las Vegas dealership changed owners from good guy brothers to an accountant with zero manners. This was my report on the Sportster forum:
2016 Moto Guzzi V7 II Stone
540 mile / 17 day report:
1. Love the low end torque...and I am already accustomed to H-D Sportsters.
2. Love the 5 1/2 gallon fuel tank
3. Love the light weight (436#)
4. Love accessibility for checking spark plugs
5. Love the black powder coated alloy wheels (does not show grime and I really appreciate tubeless tires)
6. Love key access to seat removal (two bolts on Bonneville and one bolt on Sportsters)
7. Love the seat height...not too low...not to high
8. Love the storage under the seat for a small tool bag, spare fuses, spare spark plugs, 6x9 zip lock bag of schematics, etc.
9. Love readability of the gauges...although the numbers could be a tad bigger for 70 year old eyes
10. Love the ground clearance and lean angle capabilities
11. Love the shaft drive
12. Air filter (AP8104924) is inexpensive at $8 - $9
13. Spark plugs (NGK CPR8EB-9) can be ordered from O'Reilly's for $4.49 each
14. Yuasa YTX14-BS battery equivalent is stocked at my local O'Reillys (ETX14), a factory filled AGM for $102.99
15. The 3 relays (headlight on after startup, start and injectors) are the same part number (AP8224462) and are only about $7
16. Appreciate easy access to air filter, fuses and battery, although 3 relays are under the fuel tank
17. Most sensors (and injectors) are easy access (right head temp, oil pressure switch, engine RPM, etc), but some are not (neutral switch, TPS, coils)
18. Seat has been comfortable for up 6 hour days, thus far; whereas both Sportsters and Bonneville seat required upgrades for more than 50 miles. Can better evaluate after a 300+ mile, 5 hour+ run to Stove Pipe Wells in Death Valley, planned for the end of March.
19. This is the first bike which may remain absolutely stock, other than a Dart Marlin flyscreen, removal of decals and stickers and LED tail/stop 1157. (I did add small side cases)
https://image.ibb.co/eLcMtk/left.jpg
20. Only negatives are:
Major
A. the lean mixture, both cold start (likes 2 minutes +) and even after a "warm" start after only a few minutes shutdown, which likes almost a full minute after re-start.
Minor
B. a few things are crowded under the tank/between the heads (throttle body, coil, etc.)
A ECM program update made the warm starts not quite as bad, but still very annoying.
LR, are you trying to tell all members that you've gotten your lovely CB by mistake? Confused:
Smile
Doc, I'm surprised you didn't mention the harsh rear suspension. Easily remedied but a common V7 complaint.
PB, not at all. My CB is awesome. But my growing frustration with MG parts and service finally pushed me to look elsewhere because I knew it couldn't be a sustainable relationship. I always fancied the DLX. It was a no-brainier.
(02-07-2019, 10:29 AM)LongRanger_imp Wrote: Doc, I'm surprised you didn't mention the harsh rear suspension. Easily remedied but a common V7 complaint.
I had not yet taken it to Clarkdale, AZ, about a 700 mile roundtrip.
The rough asphalt on 89A from Ash Fork to Chino Valley was a harsh ride, but most of the time it was not really an issue. It cornered very well going over Mingus Mountain on 89a from Prescott through Jerome.
It did develop a no-idle-without-throttle issue going through Jerome, which made it awkward giving rides to grandkids, but that went away, after sustained high speeds on I40.
I did report it as being harsh on the wildguzzi forum, but that was more of a side comment: https://wildguzzi.com/forum/index.php?to...msg1460374
...and this forum, last March: http://cb1100forum.com/forum/showthread....#pid199475
I had zero issues with either Sportsters, other than dealer induced:
Ventura H-D failed to lube clutch cable and it went dry on a remote canyon ride. Only one of two "first services" I paid (wasted) $ on. They spent time checking the obvious (horn and lights work, etc) but did not follow the H-D check list.
The other "first service" was on the M-G and I thought it may have been worth the $ for the ECM program upgrade. It helped, but not enough.
Simi H-D changed tires (Dunlop soft K-591 wore quick), drove out the rear axle and did not replace wheel bearings after subjecting them to impact side load. Bearings almost seized the next day on freeway somewhere in Anaheim. Also, I rode only a block before rattling alerted me to the front wheel axle pinch bolt being loose. General manager and I had a long talk. Later he bought the dealership, which had been owned by Ventura H-D and I heard that the shop vastly improved thereafter.
Both the new 2003 XLH883 and used 2002 XL1200 Sport were trouble free at 1,000 miles per month. Long stroke motors not only have good torque, but longer burn time = good mileage. The 1200 (dual plug heads, w grind cams) got 59 MPG before I rejetted it.
Both ran good after rejetting and not bad before rejetting. Rejetting mainly lowered the oil temp at sustained WOT pulling long grades. The Keihin CV40 carb was easy access.
Great suspension, adjustable front and rear on the 1200 Sport. Probably saved my life coming up to the top of Balcomb Canyon to a blind very sharp curve.
https://www.google.com/maps/place/Balcom...18.9662379
Picture hitting better than 90 MPH south on the relative straightaway, slowing to 60-70 MPH on the left sweeping turn, cranking the throttle and then recognizing, at the last moment, that the blind right is almost 90 degrees. No warning that I recall southbound, but from the other direction is is labeled 10 MPH!
https://www.google.com/maps/@34.3214393,...312!8i6656
Before the areas of the super low Sportsters, it had the lean angle to lean really low and great suspension, as well as being a very narrow 1200cc. I do not know my speed, but I really thought it was not going to negotiate that turn.
These were the last two years of lighter weight non-rubber mounted motors (2004 up) and carbs were replaced with EFI in 2007.
As much as some forum members feel the need to bash H-D or criticize the Vrod, I very much liked my Sportsters and would have bought another, but as with many things I like, my preferences were discontinued.
(+1) on the dealer situation.
I didn't know they had questionable reliability or sustainability. I thought those years were behind them some ten or more years ago. Mind you, back then the dealerships were more abound.
Triumph and Moto Guzzi both have issues keeping dealers. If the CB1100 were not available, I might have gone back to Triumph (my 2012 Bonneville was faultless), but the Las Vegas dealer is the same as for Moto Guzzi and same owners for BMW. At that point, my options were Yamaha or Honda.
And I already pursued the Yamaha option before getting the Moto Guzzi
[url=http://xlforum.net/forums/showthread.php?t=2005334&page=8]http://xlforum.net/forums/showthread.php...334&page=8
Still fortunately for us on north shore Lake Ontario, there are many Triumph dealers. In fact, all my gear is Triumph, but I don't own a Triumph because the CB came along.
Triumph has VERY good build quality.
865 cc had a lot of low end torque and pulled strong throughout the RPM range.
67 HP @ 7500, 50 ft lbs at 5800 and 495#, but it did feel cross wind gusts.
It was 112 and climbing on the Extraterrestrial Highway, wind calm, when a sudden gust from the north blew me from the middle of the W/B land to the middle of the E/B lane.
When they introduced EFI, there were some lean issues, which is why I asked the dealer to install the richer Arrow tune, but it may have been solved by then.
The dealer, in Simi Valley, did not charge for that.
When I learned no tool kit, they put one together for me.
Very much respect for that dealership.
If I were to get another Triumph, I would gladly drive 300 miles to get it and hope no service needed in Las Vegas.
You guys are a bad influence, here I am talking about another bike...
(02-07-2019, 12:06 PM)SportsterDoc_imp Wrote: Triumph has VERY good build quality.
Sorry [url=https://www.harley-davidson.com/ca/en/motorcycles/2019/sportster.html]Sportster Doc. Smile
Most of us can probably point to a bad influence for getting us started in motorcycling.
Doc, I hope someday, somehow, you're able to get back on the road. You can blame all of us.
  1915 Harley Davidson 11F Stichill 10 859 03-18-2023, 10:32 AM
Last Post: 1973cb750
  2021 Harley Davidson Pan America in Showrooms Frulk_imp 39 2,442 09-19-2021, 03:56 AM
  New Harley Electric offering coming? Frulk_imp 1 296 06-04-2021, 05:24 AM
  Harley Davidson Knuckleheads at auction. Frulk_imp 2 327 05-10-2021, 03:55 AM
  Another Harley Thread Cormanus 69 3,920 07-26-2020, 04:37 AM
  Harley Livewire - who cares? Gone in 60 58 3,673 07-04-2019, 02:19 PM
Last Post: LongRanger_imp
  Indian Harley Davidson? StackMan_imp 4 376 11-19-2018, 02:15 PM
  2019 Harley model Frulk_imp 1 232 10-25-2018, 11:37 AM
Last Post: apex1_imp
  I guess Harley is finally listening misterprofessionality 24 1,469 07-31-2018, 01:54 AM
Last Post: SportsterDoc
  2018 Harley Soft Tails hb9400_imp 50 2,535 02-21-2018, 10:41 PM
Last Post: jimgl3_imp
