Threads: 93
Likes Received: 9 in 4 posts
Likes Given: 6
Yeah, GO, not a bad little gizmo for less than $20.
Threads: 18
Likes Received: 2 in 1 posts
(04-30-2021, 10:22 AM)Stichill_imp Wrote: I swear by my [url=https://www.motionpro.com/product/08-0048]Motion Pro chain alignment tool.
![[Image: 72a6795187282d856fd5f0256fb6c84a.]](https://cb1100forum.net/forum/uploads/imp/202104/72a6795187282d856fd5f0256fb6c84a.)
I just bought that tool myself
Likes Given: 1,002
Whoops, in one of those videos, Ari shows sticking a rag in the chain and winding it on to the sprocket to keep the chain tight as you tighten the axle. That helps keep the wheel aligned as you tighten.
Likes Given: 140
In the common service manual it shows and tells you to grasp the chain with your hand and pull up while tightening the axle to keep the wheel against the adjusters. I’m not doing that.
Threads: 39
Likes Received: 15 in 8 posts
(04-30-2021, 08:21 AM)Whoops_imp Wrote: (04-23-2021, 08:40 PM)jimgl3_imp Wrote: you all are overlooking one thing... there is a green and red zones marked on your adjusters. if you have proper length chain and it's not old and stretched from excessive miles, if the adjusters are in the green zone, you're fine.
this from cb750, but shows my point
![[Image: 59aced9da8408aa72fbe7af39114921a.jpg]](https://cb1100forum.net/forum/uploads/imp/59aced9da8408aa72fbe7af39114921a.jpg)
Not to derail the slack conversation, but I feel this applies somewhat...
I just performed my first chain clean and lube today and have now adjusted the chain to as close to 1 inch of free play as I could get (owing to the few people here who agreed a slightly tighter chain seemed to shift better).
However, when adjusting the set screws it was immediately apparent that they were wildly different from one side of the bike to the other. The manual states when adjusting, make sure you perform the same turn on each side, but it mentions nothing about how to align the wheel when they are not set at the same distance to begin with.
I blame the dealer that I purchased the bike from. I have found that they claimed they changed the oil and filter (they didn't), changed the brake and clutch fluids (they didn't). The only thing they did do was goop grease on the chain that flung everywhere. And now apparently it seems they only adjusted one side.
I got out my Mitutoyo Calipers and measured the following before making any adjustments.
Chain side, before adjustment: 0.467 inches
Brake side, before adjustment: 0.596 inches
After adjusting the tension on the chain side to as close to 1 inch as possible, I then adjusted both sides to the following before torquing the axle nuts to 83 ft lbs.
Chain side, adjusted: 0.684 inches
Brake side, adjusted: 0.683 inches
![[Image: a4683a65d6776f19bcb0c3e9d2f6da30.jpg]](https://cb1100forum.net/forum/uploads/imp/a4683a65d6776f19bcb0c3e9d2f6da30.jpg)
Did I do this right or should I have left them with the disparity in the gaps because that is not how the wheel is aligned?
Woops you seem to be the type to test this out;
https://www.youtube.com/watch?v=by7L3M8ai-0
I might add that i could not do this measurement on the centerstand, it interfered with the string and also the position of the front wheel is not super critical because of the way the discs line up as you may find out.
Seem to remember that the markings on my bike were not completely in agreement with the alignment as shown here, since we're now on this subject.
It may pay to verify that yours are correct and this method will be a reliable way to check alignment in your case.
With great regard to all methods above none of them actually verify the actual wheel is in line with the front wheel, they all should do that if all other parts are accurate, the method with the string does measure the actual wheel alignment but we are realy getting into the semantic stage here.
Lord Popgun makes a good point, i adjust mine with some tension on the axle nut, something like half the torque so it stays in place and;
In addition to the adjustment i tighten the axle nut and then tighten up both adjustment bolts ccw. to prevent the axle bolt traveling forward under load since these bolts don't have a locking nut to prevent them changing position, something i might change in the future.
(04-30-2021, 01:50 PM)Stichill_imp Wrote: Yeah, GO, not a bad little gizmo for less than $20.
Yeah, great tip - thanks.
Man, I so miss the Honda shaft final drive.
Threads: 93
Likes Given: 6
(04-30-2021, 09:37 PM)GoldOxide_imp Wrote: (04-30-2021, 01:50 PM)Stichill_imp Wrote: Yeah, GO, not a bad little gizmo for less than $20.
Would be a great evolution for the AT.
Threads: 23
Hi Whoops,
Rightly or wrongly that’s exactly what I do. I am taking a leap of faith that Honda puts their frames/swingarm together to fine tolerances in the first place so I just make sure the adjusters both sides are as near to identical as I can. Then I choose not to worry about it anymore. I have tried the string method many times over the years to line up front & rear wheels on different bikes with some success but (especially on a spoked wheel) I find the wheel rims and tyres can easily run out a few mm so how do you know where you are?
Some bikes have rear wheel offset too and that messes with your head. Others may be able to confirm but I’ve had a few Harleys that I swear didn’t line up at all, like 10mm out! Anyway, the CB feels really well balanced, tracks straight so I’m confident it’s pretty accurate at the end of the day. When I spin the rear wheel over (on the stand obviously) it’s as free as anything which I take to mean it’s all tracking true with no dragging of the brakes at all.
Threads: 31
Likes Received: 117 in 50 posts
Likes Given: 64
(05-01-2021, 03:41 AM)Jfro5687_imp Wrote: (04-30-2021, 08:21 AM)Whoops_imp Wrote: (04-23-2021, 08:40 PM)jimgl3_imp Wrote: you all are overlooking one thing... there is a green and red zones marked on your adjusters. if you have proper length chain and it's not old and stretched from excessive miles, if the adjusters are in the green zone, you're fine.
![[Image: 4693767a51b19539888bf9c00fba6a33.jpg]](https://cb1100forum.net/forum/uploads/imp/202105/4693767a51b19539888bf9c00fba6a33.jpg)
Hi Whoops,
Funny you should say that about the brakes. I did hear a slight drag after setting the ends to have the same clearances. Now I wonder if I just created a problem that didn't exist before.
Threads: 39
Interesting about the brake assembly, that was the first thing i wondered about a picture that Dave sent me;
what about the brake alignment if the wheel is not straight?
Sure they can slide sideways but what about the release return of the pistons?
I guess over time the pads would wear in and adapt to the new working angle, you could measure the thickness of the pads and confirm either way, but it's a good point and not obvious initially.
