What did you do on or to your CB 1100 today
#91
(07-18-2025, 07:10 PM)peterbaron Wrote: Thanks to the tubeless tire, the ride was smooth, and the road wasn't at all winding. A low-profile radial moto tire provides the rider with increased stiffness, but only to a point.
Peter, how did you repair the tire?
(07-16-2025, 04:37 AM)Cormanus Wrote: You're a champion, Bob.  Beer
Tell me about the impact driver. Is it a new-fangled electrical one? Or is it one of those marvellous old-fashioned beasts where you put the bit in the screw head and give the end a belt with a hammer?
It's a battery operated one. Lots of bang to it!
I have the old fashioned kind but never found it satisfactory, not to mention satisfying.
Anyhow, I now feel just like a Formula One pit crew guy!
Whoops
Inhouse BobAll righty! Perhaps earn I will the Full Jedi Badge from Lord Popgun with all the servicing I have given the bike this month. At around 40k miles, I thought I'd better learn to do some stuff.
- New tires (Angel GT radials, as before. Thanks to Euro Motorsports of Asheville for the mounting. Good folks).
- New oil and filter (OEM filter and Honda 10w30 dinosaur renderings).
- New sprockets (OEM ratio. Thanks to several forum folks for advice and consultation on this one).
- New chain (of course).
- New sparkplugs.
- New air filter cartridge.
- New brake pads front and rear.
- New mount for the GPS (left the old one attached to my rental bike in Italy, dang it).
- New chromium bar ends donated by a fellow forum member a good while ago. Thanks, Christian!)
I gotta say, I enjoyed most of the the process. Special thanks to forum member and neighbor Mark for his help and supervision. Sorry about the occasional blue language.  Angel
The brake pads , chain and sprockets showed no significant wear and could have gone many, many more miles. But while I was in there, why not?
I also got to purchase some fun new tools. I especially like my fancy impact driver. I need to find more things to impact!
So, I'm ready for the rally. See everyone there!
Biker Biker Biker Biker Biker
I'm so curious to see a picture of the new shiny bar ends. Do you perhaps have one? I find it very interesting to see how people have customized their bikes.
I'll get a shot for you. Meanwhile, they came off of a 2014 DLX, so you can spy them there.
Been around longer than that! Cool
Plug n play from outside.
Not to most professional way but this tire will soon be replaced with T32
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
I got a plug kit on Amazon, but haven’t got one to work without leaking.
Mind sharing info for your plug kit?
Ah. I've got one of them too. It's fun for driving screws into tough wood, but somehow less satisfying than the old-fashioned one when it works. Which it doesn't always.
I got tags for my new-to-me CB1100 this morning.  Woo-hoo!
Over the weekend, I got started on the muffler swap.  I removed the right aftermarket muffler with great difficulty and sweated at least a pint in the process.  Went inside to cool off, change out wet clothes, and replace the sweat with a pint of beer.
Recovered some motivation, went back into the garage to tackle the left muffler, and failed (so far).  I think if I get some time this week I'll search for the bernzomatic and try hitting it with heat.
After giving up (temporarily) on the left side, I did a little clean up on the original right side muffler, mostly because it was something I could do inside the air-conditioned house.  It cleaned up nicely except for some small pitting/rust on the bottom/inside of the pipe.  Although this is the non-visible side, I thought I'd try to clean up the pitting.  Using the aluminum foil and water technique, it worked pretty well.  I'll put some chrome polish on it before I install it.
Attached Files Thumbnail(s)
Nice job, Lunchbag. I have had good success on rusty metal using Loctite Rost Remover Naval Jelly. Let it sit for twenty minutes or so and wash it off. It is pretty strong stuff, so wear rubber gloves and keep it away from your eyes. It will remove paint, too, so be careful with it.
There's a difference in riding a naked bike and riding a bike naked.
Won't make that mistake again.
2013 Honda CB1100 Standard. Gone, but not forgotten.
My friend who specializes in rebuilding and restoring vintage motorcycles uses 10% vinegar with salt or baking soda. I don't know the exact proportions, but I can ask him if necessary.
            *Grand Chancellor*
[Image: e1fZiOZ.jpg]
I also bought ^this^ particular set on Amazon, except for the red and blue rubber plugs I brought home from work. I keep this kit at home.
I don't use string plugs because I find rubber is more flexible and holds tire pressure better, so rubber on rubber, always with glue. No leaks.
Then I only cut off 2-3 mm of excess above the tire. I don't use a flame for the repair.
Just remember that repairing motorcycle tires is not recommended due to the warning on the sidewall—they should be replaced.
If you have a tubeless tire, get a nail or screw and don't carry a tire repair kit, you can always inflate the tire to its maximum pressure without removing the nail... and in most cases, you'll get home safely.
I also have a portable tire repair kit with three or four CO2 cartridges, and if I'm going on a trip longer than 1,000 miles, I usually take a portable 12V air compressor with me.
I've never been stranded or towed.
For cars, I use a different procedure at the workshop. I use mushroom-shaped rubber plugs that I install from the inside of the tire, and glue. I never plug the sidewall or shoulders of a tire, nor use two or more plugs, nor repair any tire that is not safe according to Department of Transportation (DOT) regulations. For a specific reason, a car tire can be inflated to its maximum allowable pressure, which is higher than the factory-set pressure.
[Image: ToLVyrB.jpg]
            *Grand Chancellor*
(07-21-2025, 09:19 AM)Lunchbag Wrote: I got tags for my new-to-me CB1100 this morning.  Woo-hoo!
Nice work. I have used products from Chemical Guys to address similar situations with great success. Do not know if this product is right for the job but thought you might like to check it out:
https://www.chemicalguys.com/products/he...ish-bundle
David
2017 Honda CB1100 EX
  What did you do on or to your CB 1100 today Part 2 the Ferret 53 6,125 05-07-2025, 09:13 PM
  NEW 2014: CB 1100, CB 1100 EX ingobohn_imp 210 16,554 01-10-2014, 12:04 AM
Last Post: rboe
