Tailbag: Kriega US-10 Drypack - Printable Version
+--- Thread: Tailbag: Kriega US-10 Drypack (/showthread.php?tid=9496)
Tailbag: Kriega US-10 Drypack - Huladog_imp - 06-24-2013
I wanted a small bag just to carry a few items on my rides like a water bottle, snacks, maybe a light rain jacket. Kept checking out different bags but didn't like a lot of the mounting systems until I took a closer look at the Kriega system of straps.
This is one of their smaller bags which suits my needs and they do have larger units plus you can piggy back small bags on the top of the larger bags.
When empty the bag has a low profile so its easy to swing your leg over the seat (I used to ride a BMW R1200RT and had to be careful not to kick the tops of the big saddlebags). Those silver alloy clips connect the bag to the mounting straps. The straps on the bag itself also have quick release buckles.
The adjustable mounting straps wrap around the conveniently located subframe under the CB1100 seat. You could also just connect the straps together and loop them under the seat.
The nice thing is that you can quickly detach the bag itself from the straps, leave the straps mounted and tuck them underneath the seat.
There are a bunch of less expensive tail or seat bags but their mounting systems of straps wrapped around passenger pegs, etc. didn't look too secure. The Kriega system seems robust as well as versatile.
To figure out more ways to use their bags go [url=http://www.kriega.us/bike-packs/]visit their site.
(Yes, that is a Staintune and if you get one you won't regret it.)
Aloha,
Huladog
RE: Tailbag: Kriega US-10 Drypack - ChipBeck_imp - 06-24-2013
Huladog,
Nice writeup, great pictures, new product I've not heard of before. Well done.
Chip
RE: Tailbag: Kriega US-10 Drypack - Joola_imp - 06-25-2013
When not using the pack, do you just tuck the straps over the fender and snap the seat over top of them? Those bags looks really nice. I like the mounting system more than plastic clips my Ogio bag has. I'm worried they won't last very long.
RE: Tailbag: Kriega US-10 Drypack - Rolls_imp - 06-25-2013
Very thoughtfully designed bag. Sort of a tidy, minimalist approach to baggage, which I like. Great post and pics, Huladog!
RE: Tailbag: Kriega US-10 Drypack - Huladog_imp - 06-25-2013
(06-25-2013, 12:52 AM)Joola_imp Wrote: When not using the pack, do you just tuck the straps over the fender and snap the seat over top of them? Those bags looks really nice. I like the mounting system more than plastic clips my Ogio bag has. I'm worried they won't last very long.
Yes, you can just flip the straps onto the fender under the seat without having to undo the straps. The straps are adjustable so you could wrap them around those bungie tie down spools by the seat if you wanted a wider base to secure the bag to.
The Kriega material is pretty heavy duty, more like the stuff they make inflatable life rafts out of then light nylon with a waterproof coating.
Aloha,
Huladog
RE: Tailbag: Kriega US-10 Drypack - Guth_imp - 06-25-2013
I just purchased a Kriega R25 backpack this past week. Very pricey stuff, but it is obvious that there was some serious thought behind the design and equally serious effort put into the execution of this product. The harness system is spectacular and the quality of the hardware and materials is all top notch. I've found that I prefer a backpack over the other available luggage options for my commuting needs, and the R25 fits the bill perfectly. If I wasn't commuting by bike and planning on using this pack on a daily basis, I'd save my money for some other, more fun, accessories (such as that Moriwaki slip-on megaphone exhaust). But I can tell that this will be money well spent. Good stuff.
RE: Tailbag: Kriega US-10 Drypack - ChipBeck_imp - 06-27-2013
(06-24-2013, 03:54 PM)Huladog_imp Wrote: I wanted a small bag just to carry a few items on my rides like a water bottle, snacks, maybe a light rain jacket. Kept checking out different bags but didn't like a lot of the mounting systems until I took a closer look at the Kriega system of straps.
Aloha,
Huladog
Huladog,
I just got my Staintune and I noticed something in your photo above. The tab that is welded to the top of your Staintune that bolts to the rear peg mount is suppose to go behind the rear peg brace and you have it in front of the peg brace. Rotate it so that it bolts to the rear of the brace and it will hide that tab and look better. Cheers bro.
Chip
RE: Tailbag: Kriega US-10 Drypack - Huladog_imp - 06-27-2013
Chip
Hey, thanks for noticing that will go tweak the setup when I get home. The thing went together so easily I didn't even think about it.
Mahalo,
Huladog
RE: Tailbag: Kriega US-10 Drypack - ron1100_imp - 06-29-2013
Any thoughts on the Kriega US-20? Just wondering if it'd be too wide to take away from the lines.
RE: Tailbag: Kriega US-10 Drypack - Riko_imp - 01-06-2016
(06-29-2013, 03:00 AM)ron1100_imp Wrote: Any thoughts on the Kriega US-20? Just wondering if it'd be too wide to take away from the lines.
[Image: fb84f0dcf572f8889b16da9a8a57e7fd.jpg]
5-10-20
