Where is the ECU located?? - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Accessories/Modifications (https://cb1100forum.net/forum/forumdisplay.php?fid=8) +--- Thread: Where is the ECU located?? (/showthread.php?tid=9308) |
Where is the ECU located?? - daskraut_imp - 06-23-2016 I just got a spare ECU reflashed and want to install....so where is the damn thing located??? RE: Where is the ECU located?? - kmoney_imp - 06-23-2016 Pull the gas tank. It's sitting right under the middle of the gas tank. Pulling the tank is the one 12mm bolt at the back, removing left hand side panel to disconnect 3-pin fuel pump connector, lifting the rear of the tank and disconnecting the fuel line and vent line and pulling the tack off towards the rear. RE: Where is the ECU located?? - Lord Popgun - 06-23-2016 Daskraut, it is under the tank. Here is a pic. There are others. http://cb1100forum.com/forum/showthread....2#pid48262 I posted that for you in another thread daskraut. Just do what Kmoney said to get to it
RE: Where is the ECU located?? - Randy B - 06-23-2016 (06-23-2016, 09:33 PM)Lord Popgun_imp Wrote: Daskraut, it is under the tank. Here is a pic. There are others. http://cb1100forum.com/forum/showthread....2#pid48262 That link doesn't work. RE: Where is the ECU located?? - Lord Popgun - 06-23-2016 Randy, try again: http://cb1100forum.com/forum/showthread.php?tid=3170&pid=48262#pid48262 I think it was messed up due to the way I copied it from my other post. |
