H-B mini rack on a '17 RS - Printable Version
+--- Thread: H-B mini rack on a '17 RS (/showthread.php?tid=8978)
H-B mini rack on a '17 RS - Macduff_imp - 07-23-2017
I stumbled across this Hepco and Becker Mini rack on ebay for a very modest sum. I was after a rear rack to ferkle with so I could fit my left over Touratech rear rack mount (off a previously owned XT1200Z) so didnt want to spend big or buy new given I was going to modify both bits.
Heres a pic of the HB rack as it appeared on ebay
And heres the fitted article with the cutdown Touratech mount bolted onto the H-B rack plate.
I test fitted the Touratech Zega Topbox I had kept (and fitted to various bikes) since selling the XT1200Z.
I still need to sort the mounting of the TT base plate so that its mounts are spreading the load around the HB plate , but will need to sort some decent drill bits as the TT mount is stainless steel and a pita to drill freehand.
I had cut the original yamaha specific mounting plates off the TT base as it would have raised the base up higher than I wanted plus it was a flawed design that placed the four mount holes close together at the front so the Topbox weight acted as a lever and fractured one of the mount bolt holes. I'm using 3 current holes already in the TT mount to fit to the HB plate but these wont take the stress once loaded so will need 4 more better distributed holes drilled in both spread the load. I also need to trim the topbox mounts to relieve the interfence fit around the front mounts and HB rack but thats a minor task compared to the holes. Any tips on drill Stainless steel plate with a hand held power drill welcome. I'm starting small and slow.
RE: H-B mini rack on a '17 RS - easy_imp - 08-23-2017
Thx for your post. I guess is the only real life picture of HB rack on RS in whole internet :-)
I'm just about to order same model , then give a try with soft bag on it.
Cheers!
RE: H-B mini rack on a '17 RS - Houtman_imp - 08-23-2017
(07-23-2017, 12:07 AM)Macduff_imp Wrote: I stumbled across this Hepco and Becker Mini rack on ebay for a very modest sum. I was after a rear rack to ferkle with so I could fit my left over Touratech rear rack mount (off a previously owned XT1200Z) so didnt want to spend big or buy new given I was going to modify both bits.
Try cobalt bits and some cutting/drilling oil
RE: H-B mini rack on a '17 RS - easy_imp - 08-24-2017
looking onto CRF1000L pictures from 2016 and seems to me its exactly same tank cap - 5 fitting screws on same layout ?
anybody have a access to both bikes to compare ?
please !
p.s. givi is selling tanklock adaptor for it, its BF25 model
RE: H-B mini rack on a '17 RS - Macduff_imp - 08-24-2017
Try cobalt bits and some cutting/drilling oil Yup that's what I did. Worked a treat and made the titanium coated bits looks like they were made of cheese.
(08-24-2017, 02:13 AM)easy_imp Wrote: looking onto CRF1000L pictures from 2016 and seems to me its exactly same tank cap - 5 fitting screws on same layout ?
please !
Have you compared the part numbers for both on a Honda parts site?
Nope, I'm new to Honda plus onboard vessel at North Atlantic with very limited access to the network :-(
Guessing that numbers will be different as one is plastic painted and other is chrome
RE: H-B mini rack on a '17 RS - easy_imp - 08-25-2017
Right, this is the moment of truth ;-)
https://www.bike-parts-honda.com/microfiches-recherche_piece-17620-MJE-D01.html
Same cap used on few models, including new AT
So...givi BF 25 will work !
With XS307 , 15 liters may work well for my taste.
What's more important, the tanklock on tankbag may be shifted forward , same time tankbag will move to the seat direction to avoid collision with handlebars
Just a thought, time will tell :-)
