My other bike- '81 XS400 - Printable Version
+--- Thread: My other bike- '81 XS400 (/showthread.php?tid=7564)
My other bike- '81 XS400 - doubleg_imp - 05-29-2015
Just thought I would post some pics of the latest iteration of my ongoing project bike. Bought it last year for $500 (with valid title). Was pretty much stock, black in color, missing a few items such asair filters. Engine ran when I bought it, but carbs were not quite set up correct and would die almost instantly as soon as put it in gear and set out on the road. Bought some generic pod filters, rejetted, and replaced leaky exhaust, what a difference.
I should have kept better track of what i put it into it money wise, I'm guessing between 1000 and $1500. Probably wont get the return on my investment, but I bought it just to have something to tinker with.
Made the seat/rear cowl myself out of fiberglass and a ton of bondo.
Rattle can paint job, holding up better than I expected, althought the frame is showing signs of abuse. I may have to touch some of those spots up.
RE: My other bike- '81 XS400 - Rocky_imp - 05-29-2015
Nice Thumbs Up Thumbs Up
RE: My other bike- '81 XS400 - Scoobynut_imp - 05-29-2015
Really nice looking bike, doubleg, nice work! You mentioned touching up the paint on the frame -- when I was restoring my RD400, the frame paint was in really good condition, except the front downtubes where the previous owner had installed clamp on crashbars; there was surface corrosion where the clamps had removed the paint.
I used some POR15 products to touch up those spots and you would be hard pressed to know where the paint has been touched up. From the POR15 starter kit I used their Marine Clean degreaser and the Metal Ready prep to clean and prep the corroded spots, then after drying I used their black gloss Top Coat paint on the frame. Rather than taping everything off and spraying the paint onto the frame, I sprayed paint onto a piece of cardboard and used a foam brush like you would use for house painting to dab the paint on. The POR15 Top Coat paint when applied with a foam brush doesn't show lines or 'orange peel' when applied with the foam brush, it just lays down flat like you sprayed it. In any case, I got very good results with this method, so you might consider giving it a try. As a bonus, the paint when applied with this method will hold up much better than typical spray paint and will arrest any further corrosion. I can get you some photos of the results if you want to see them.
RE: My other bike- '81 XS400 - doubleg_imp - 05-29-2015
(05-29-2015, 02:31 AM)Scoobynut_imp Wrote: Really nice looking bike, doubleg, nice work! You mentioned touching up the paint on the frame -- when I was restoring my RD400, the frame paint was in really good condition, except the front downtubes where the previous owner had installed clamp on crashbars; there was surface corrosion where the clamps had removed the paint.
Would love to see those photos! Most of the touch-up area's I would need to do is on the swingarm. I think that might be because i completely stripped the paint off that, and I'm guessing the primer I used wasn't up to the task. The rest of the frame I just sanded as needed and painted over and it seems to be holding up better.
I like your idea for touch up using the foam brush, I really don't feel like taking everything back apart or doing intricate taping jobs! (at least not until I get tired of the current color scheme)
RE: My other bike- '81 XS400 - emptysea - 05-29-2015
Great looking bike. Love the Rt. 66 graphics. I have a long way to go on my project bike.
RE: My other bike- '81 XS400 - Papa Weeley_imp - 05-29-2015
Very cool - nice job!
RE: My other bike- '81 XS400 - Motogeezer1949_imp - 05-29-2015
I had a 77, red, stock. Low miles, ran great.
Also at the same time, had a 77 RD400.
Pics of both in the albums on my Face Book page.
Fun bikes. Like yours, lots of creativity Wink
RE: My other bike- '81 XS400 - flynrider - 05-29-2015
Beautiful bike! Great job bringing it back to life.
I had a KZ400 and my brother had an XS400. They don't make bikes like that anymore.
RE: My other bike- '81 XS400 - Scoobynut_imp - 05-31-2015
Sorry for the slow reply, doubleg -- I have a teenager back from college and being his butler is a full time job. I'll get some photos for you today and post 'em up. You shouldn't need to do any priming or sanding (unless you just want to smooth the surface down a bit more) with the method I use.
Okay, doubleg, here are a few photos I took of the touch up I did on my RD.
I cropped an old picture I had so I could show what it looked like before I did the touch up (1st picture). The frame actually looked quite a bit worse than the photo shows, especially the other side -- sorry I don't have any 'before' pictures of the other side. One thing you've probably noticed on these old steel-framed bikes is that any frame joints and added frame bosses usually have some kind of rust around the welds. I treated all those areas too before the touch up as described in my original post. Anyways, here are the photos. Again, the first one is the only 'before' picture I have, the rest are other areas I also touched up, including parts of the swing arm (last photo).
Not a great picture, but you can see where there was some surface rust by the header pipes from the crash bars that were mounted on the frame.
[url=http://s173.photobucket.com/user/cyrenus/media/photo%204%20zoom_zpsflx0luzf.jpg.html][Image: 48cbb9ba05a68affc43039694b90e399.jpg]
Same part of the frame, after:
[url=http://s173.photobucket.com/user/cyrenus/media/DSC00437_zpsdoudbtt3.jpg.html][Image: cb72a6cc4ed88e3f69327f324933c8a8.jpg]
Other side. This side had surface corrosion all over the down tube. The little black lines are just a reflection:
[url=http://s173.photobucket.com/user/cyrenus/media/DSC00438_zpsuhviy6i8.jpg.html][Image: 0a05030a9ca50aad64d24cd16645b030.jpg]
This foot rest bracket was almost all surface rust:
[url=http://s173.photobucket.com/user/cyrenus/media/DSC00439_zpspf02cbar.jpg.html][Image: f2c40323e5dfff9e40c2d1226dd98f0d.jpg]
This part of the swing arm had some corrosion in places, especially near any welds:
[url=http://s173.photobucket.com/user/cyrenus/media/DSC00440_zpse0o97tm5.jpg.html][Image: bee2ae6222070eba396008a67d9d5fe0.jpg]
Again, all this was done with only a foam brush. You can see how smoothly the POR15 Top Coat lays down on the metal. It's also much tougher and resistant to chipping than regular paint. The Marine Clean and Metal Prep as mentioned in my first post are done beforehand to help prep the surface for paint, and will also prevent any further rust in the areas you treat with them as the Metal Prep has some chemical qualities that arrest rust and bond the paint to the treated corrosion. Hope you have the same good results I did if you decide to try this!
