Mounting hard side cases - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Other Stuff (https://cb1100forum.net/forum/forumdisplay.php?fid=16) +--- Forum: Other Bikes (https://cb1100forum.net/forum/forumdisplay.php?fid=17) +--- Thread: Mounting hard side cases (/showthread.php?tid=6327) |
Mounting hard side cases - SportsterDoc - 12-13-2023 This may not be applicable for the CB1100, but since this is the "other bike" section, it may find use for your "other bike" I used Pelican cases on my 2016 Moto Guzzi 7II. Photos below: Fender washers may not have been necessary inside the case, but I like robust. I taped the bracket for 5 mm bolts, then added locking nuts to the back side. May not have been necessary. Pelican 1170 cases https://www.pelican.com/us/en/product/cases/protector/1170 Interior (L×W×D) 10.54 x 6.04 x 3.16 in (26.8 x 15.3 x 8 cm) Exterior (L×W×D) 11.64 x 8.34 x 3.78 in (29.6 x 21.2 x 9.6 cm) Apache 1800 cases used on my current Moto Guzzi V7-850 https://www.harborfreight.com/1800-weatherproof-protective-case-small-black-64550.html Internal dimensions are 8 1/8" x 5 5/8" x 3 3/4" RE: Mounting hard side cases - Gone in 60 - 12-13-2023 That is pretty cool! I have Givi monokey mount plates on all of my bikes, and I have always wanted to figure out a way to fabricate a "box-end" hardware setup to be able to securely mount any box I want. In particular, I'd want to attach the hardware to an old-school aluminum briefcase, which would be a good vintage look for any of my bikes. If you have any ideas for me, I'm all ears... |
