Motorcycle Soundtracks - Printable Version
+--- Thread: Motorcycle Soundtracks (/showthread.php?tid=6319)
Motorcycle Soundtracks - GoldOxide_imp - 03-02-2024
Feature: 2021 Moto Guzzi V85TT Tractor with a Zard exhaust can.
These sound samples were taken on the somewhat damp and salty day of March 2, 2024.
Here is the recording device used:
This is a not so new Instamic device that is basically a MEMs-based weather-resistant remote stereo microphone with wireless capabilities. I did not use it in wireless mode. If interested, more information can be had here:
https://instamic.io/
This is where I placed the device:
Basically it rode behind me. I put the rather thin "wind screen" over it. It wasn't the best, but it helped a little with wind noise.
The following are links to sound samples:
[url=https://1drv.ms/u/s!AljFuwiPmWVni1W0UUePnD0BZe3y?e=RDz7Hy]Sound: Idling
[url=https://1drv.ms/u/s!AljFuwiPmWVni1rPlSkbKzMDMGZj?e=mq8tde]Sound: Passing Cage on Freeway
[url=https://1drv.ms/u/s!AljFuwiPmWVni1Z7l3oj6LFagTaK?e=wwTeUq]Sound: Freeway Cruising
[url=https://1drv.ms/u/s!AljFuwiPmWVni1cNVvDgphEpAt-4?e=PemiGm]Sound: Offramping
[url=https://1drv.ms/u/s!AljFuwiPmWVni1lzb8wBIDxflecS?e=Vqh0Zd]Sound: Local Block 1
[url=https://1drv.ms/u/s!AljFuwiPmWVni1jCrOlO6s_JF4bJ?e=PbTrzk]Sound: Local Block 2
Those are the sample sounds of The Tractor.
I can only imagine how the sound might be with the CB1100 opening up wide. Smile
RE: Motorcycle Soundtracks - Tev62 - 03-03-2024
Good going, I have tried to capture the CB sound a few times and it is a challenge to get any half decent sound at all. These are great representations.
RE: Motorcycle Soundtracks - GoldOxide_imp - 03-03-2024
I totally agree with you Tev.
That is why I tried a bit harder because members in other forums are struggling.
I did some more recording today and the resultant sound quality is getting better for me. That is, less wind noise, more bass sound. Too bad I don't have an inline-4 to conveniently hop on and pop onto the freeway.
I suspect at some point I should be able to finesse a sound bite, loop it endlessly and use it for meditative purposes. (truth be, I'd probably fall asleep instantly)
