wiring diagram - Printable Version
+--- Thread: wiring diagram (/showthread.php?tid=6239)
wiring diagram - earzone_imp - 07-20-2013
hi guys..
if someone has access to a shop manual could you please post the wiring diagram? if possible with the legend Smile)
Thanks!
jörg
RE: wiring diagram - Lord Popgun - 07-20-2013
I would. But its copyrighted...
RE: wiring diagram - dailyrider_imp - 07-20-2013
(07-20-2013, 03:19 AM)Lord Popgun_imp Wrote: I would. But its copyrighted...
The page is to large for my scanner. I will check out the scanners at work to see if one is large enough.
 RE: wiring diagram - earzone_imp - 07-20-2013
Hey dailyrider ..
Many thanks for your efforts! Wink You are awesome Smile
RE: wiring diagram - meowguy_imp - 07-20-2013
Copyrighted material should not be posted here. If Guth gets a notice we all lose out.
RE: wiring diagram - FUZZY_imp - 07-21-2013
I think "fair use" will apply.
RE: wiring diagram - meowguy_imp - 07-21-2013
(07-21-2013, 12:53 AM)FUZZY_imp Wrote: I think "fair use" will apply.
If you have the drawing have him call you on the phone and you could answer his question. That passes the sniff test for me.
 RE: wiring diagram - earzone_imp - 07-23-2013
Hey guys..
thank you for your help. Now i've got a circuit diagram. I'm happy Smile 'Cause i've found the failure! Wink
greets Jörg
RE: wiring diagram - ron1100_imp - 07-23-2013
Mind sharing the failure and solution?
Smile i try to install a gipro ds gear-indicator ( http://www.healtech-electronics.com/ ) i'm searching for the data link connector and found a red plug.. but it seems this is the abs service check connector Rolleyes
so now i'll try to find the dlc-connector Big Grin
(07-23-2013, 09:46 PM)ron1100_imp Wrote: Mind sharing the failure and solution?
