ecu - Printable Version +- The CB1100 Community Forum (https://cb1100forum.net/forum) +-- Forum: Honda CB1100 Discussions (https://cb1100forum.net/forum/forumdisplay.php?fid=5) +--- Forum: Mechanical & Technical (https://cb1100forum.net/forum/forumdisplay.php?fid=7) +--- Thread: ecu (/showthread.php?tid=6033) Pages:
1
2
ecu - 4845mike_imp - 06-04-2014 Does anyone know how to identify and remove the ecm so that i can have it reflashed? RE: ecu - Lord Popgun - 06-04-2014 Here is a link to a picture of it: http://cb1100forum.com/forum/showthread.php?tid=2618 It is located on top of the frame under the tank. You have to either lift the tank carefully (Ridem said you can get to it this way I believe) or remove it. There are some pics here with it installed that show you this, but I have searched for 30 mins and cannot find them. RE: ecu - CIP57_imp - 06-04-2014 (06-04-2014, 01:57 AM)4845mike_imp Wrote: Does anyone know how to identify and remove the ecm so that i can have it reflashed?Hey Mike, You have to remove the left side cover and tank. Once the tank is removed its right there in the middle toward the back. Be careful when taking it out the support bracket is very weak. The left side cover removal is to disconnect the fuel pump harness. If you don't have a shop manual PM me. This is what your looking for:: [url=http://s1034.photobucket.com/user/cipolla57/media/photo_zps9627c979.jpg.html]
ecu - Ridem32_imp - 06-04-2014 Hey mike are you sending it to don at gulth motors. ? Me. & CIP sent ours to him for the flash. Is yours a 13 or 14 model. ? RE: ecu - Offroad - 06-04-2014 Pardon the dumb questions, but Are the flashes customized or do they have a set profile for CB1100's? Beside removing the top speed limit, what are the other benefits? If the exhaust has been modified, is that taken into account? How much does Guhl Motors charge? RE: ecu - Lord Popgun - 06-04-2014 Ridem had a pretty extensive thread on this somewhere. But he will jump in and can answer all this. RE: ecu - CIP57_imp - 06-04-2014 (06-04-2014, 04:29 PM)offroadfx4_imp Wrote: Pardon the dumb questions, but No one has brought Don a stock or modified CB yet. The flash will take away the speed limiter, lower gear timing retard. I had the stock PC5 map flashed into mine and I'm running a full Yoshi and it runs great with no flat spots. Ridem32 had his flashed with just the restrictions removed. The cost is 375.00 RE: ecu - CB4ME_imp - 06-04-2014 (06-04-2014, 10:07 PM)CIP57_imp Wrote:(06-04-2014, 04:29 PM)offroadfx4_imp Wrote: Pardon the dumb questions, but Honda could have easily tuned the engine for 100+ hp. I understand their reasoning for keeping things mellow and emphasizing excellent torque that starts at the low end. Don says an ECU reflash will unleash the inherent power in the engine. What exactly did Honda do to tame the beast (besides the speed limiter)? Did they retard or delay timing in just the lower gears? Didn't they want to emulate some of the engine vibrations of the old CB750s to give it some "character"? How did they do that? Timing? RE: ecu - CIP57_imp - 06-05-2014 (06-04-2014, 11:08 PM)CB4ME_imp Wrote:(06-04-2014, 10:07 PM)CIP57_imp Wrote:(06-04-2014, 04:29 PM)offroadfx4_imp Wrote: Pardon the dumb questions, but Honda could have easily tuned the engine for 100+ hp. I understand their reasoning for keeping things mellow and emphasizing excellent torque that starts at the low end. Don says an ECU reflash will unleash the inherent power in the engine. What exactly did Honda do to tame the beast (besides the speed limiter)? Did they retard or delay timing in just the lower gears? Didn't they want to emulate some of the engine vibrations of the old CB750s to give it some "character"? How did they do that? Timing? Hey CB, I don't think this bike will ever see 100HP at the rear wheel, the cam profile won't allow that kind of power. There is power to be found in the ignition timing and a\f ratio but there is not much on top do to the cam. I believe the cam is also where the added a roughness to the engine as you mentioned. I questioned Don about the lower gear restriction and why it did not improve 100% throttle input. He said it more in the 20-40% range, however the Yoshi full exhaust did open the bike up to some larger gains. RE: ecu - 4845mike_imp - 06-05-2014 (06-04-2014, 03:43 PM)Ridem32_imp Wrote: Hey mike are you sending it to don at gulth motors. ? Me. & CIP sent ours to him for the flash. Is yours a 13 or 14 model. ? it is a 13,and yes sending it to GULTH |
